System.Runtime.InteropServices.COMException (0x80004005): Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL)) at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingF
Hi there,
I'm working on huge assembly which has around 500+ components and lots of subassemblies. Some rule are executed from main assembly and give the below error. When I run the same rule in particular assembly then it's running fine.
Error:
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.ComponentOccurrence.set_BOMStructure(BOMStructureEnum )
at iLogic.ComponentInRule.SetActiveState(ComponentOccurrence compo, Boolean valb, Boolean onlyBOMStructure)
at ThisRule.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
What could cause this error?
Bhavik Suthar
