System.NotImplementedException inventor presentation file on update function.
I try to update a presentation file, but it always throws an error. System.NotImplementedException
is somethink missing in the inventor API?
the update function works on all other filetypes but not on a Presentation file?
the save function works on presentation files but not the update or update2 function.
somebody please help. see code below.
Regards Kent boettger
 Private Sub TryUpdatePresentation()
        m_InvApp = GetObject(, "Inventor.Application")
        Dim x_CurrentDoc As Inventor.Document
        x_CurrentDoc = m_InvApp.ActiveEditDocument
        Dim thisdoctype As DocumentTypeEnum = m_InvApp.ActiveEditDocument.DocumentType
        If thisdoctype = DocumentTypeEnum.kPresentationDocumentObject Then
            Dim x_PresentDoc As Inventor.PresentationDocument = m_InvApp.ActiveEditDocument
            x_PresentDoc.Update()
            MsgBox("Presentation file Update OK!")
        End If
        If thisdoctype = DocumentTypeEnum.kAssemblyDocumentObject Then
            Dim x_AssemblyDoc As Inventor.AssemblyDocument = m_InvApp.ActiveEditDocument
            x_AssemblyDoc.Update()
            MsgBox("Assembly file update OK!")
        End If
        If thisdoctype = DocumentTypeEnum.kDrawingDocumentObject Then
            Dim x_DrawingDoc As Inventor.DrawingDocument = m_InvApp.ActiveEditDocument
            x_DrawingDoc.Update()
            MsgBox("Drawing file update OK!")
        End If
        If thisdoctype = DocumentTypeEnum.kPartDocumentObject Then
            Dim x_partDoc As Inventor.PartDocument = m_InvApp.ActiveEditDocument
            x_partDoc.Update()
            MsgBox("Part update update OK!")
        End If
    End Sub
adam.nagy
Autodesk Support
Autodesk Support
Hi Kent,
Yes, that seems to be correct.
I cannot see an update button in the UI either - under the QAT (Quick Access Toolbar)
I don't have much experience with presentation documents, but could you tell me what you are trying to achieve?
How do you get a presentation document into a state that it needs an update?
Cheers,
Adam Nagy
Autodesk Platform Services
I change some iProperties? for example.
adam.nagy
Autodesk Support
Autodesk Support
Can you drive something in a presentation document with an iProperty, or how does that make the presentation view out-of-date requiring an Update?
Can you just provide some steps to get to a point when doing an Update would change the presentation view?
Also how do you update in the UI?
Adam Nagy
