System.MissingMethodException
When I run the following code, I get an exception.
Spoiler
    Public Sub MySub()
        Dim MainFile As System.IO.FileInfo = Nothing
        MainFile = GoDoSomething()
    End Sub
    Public Function GoDoSomething() As System.IO.FileInfo
    End Function
The following exception happens when MainFile is initialized:
System.MissingMethodException: Method not found: 'System.Collections.Generic.List`1<System.String> Autodesk.DataManagement.Client.Framework.Vault.Forms.Settings.SelectEntitySettings.get_ActionableEntityClassIds()
I think there is something wrong with my references, but I'm not sure what the last part of the exception is referring to (get_ActionableEntityClassIds()).Everything else can be seen in the object browser. I tried using the 4.0 framework, but the version 20 vault references couldn't find themselves anymore. Any help would be most appreciated.
Mike
Let me update my findings...
I think I've found what is causing the exception, but I'm confused as this was working a few minor changes ago (references were upgraded), and the method in question seems to be allowable (at least what I think the method is).
Public Sub MySub()
End Sub
    Dim TestBool As Boolean = False
    Dim testFile As ACW.File
    Dim ProjFolder As ACW.Folder = mgrAdmin.DocumentService.GetFolderByPath("$/Projects/")
    Dim Folder5000 As New VDF.Vault.Currency.Entities.Folder(conn, ProjFolder)
    Dim EntSettings As VDF.Vault.Forms.Settings.SelectEntitySettings = New VDF.Vault.Forms.Settings.SelectEntitySettings()
    With EntSettings
        .ActionableEntityClassIds.Add("FILE")
        .DialogCaption = "Select Welded Main Assembly Drawing"
        .MultipleSelect = False
        .ConfigureActionButtons("Select File", Nothing, Nothing, Nothing)
        .InitialBrowseLocation = Folder5000
    End With
End Function
I think there is something wrong with my references, but I'm not sure what the last part of the exception is referring to (get_ActionableEntityClassIds()).Everything else can be seen in the object browser. I tried using the 4.0 framework, but then the version 20 vault references couldn't find themselves anymore. Any help would be most appreciated. I don't understand how anything in the exception relates to the line of code that blows up.
Mike
I got this working hurridley before winter break. I believe the problem was coming from the fact that I had just upgraded Inventor, and hadn't installed the updates for 2015. I could be mistaken, but it was not a code issue. Either that or it came from a duplicate reference that I remember finding using Process Explorer. Sorry I couldn't be more specific.
Mike
