System.IO.FileNotFoundException Error
nagihan.bostan
nagihan.bostan
I am create an add-in for Inventor 2024 with C#. My project interacts with a web api that I have built in a separate project.
I am using the "System.Text.Json" package for this. But after the program runs, I get an error where I use "System.Text.Json".
Information
1)Post-buil event command line is empty.
2)Output Path:ProgramData\Autodesk\Inventor2024\Addins\ProjectFolder\
Error!
There is a similar thread in the link. I tried the solution but still same got error. (https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/nuget-package-reference-while-debugg...)
Thanks in advance for help.
Michael.Navara
System.Text.Json is available since .NET 5. But for Inventor AddIn you need to use .NET Framework 4.8.
Try to use Newtonsoft.Json NuGet instead
nagihan.bostan
Thanks for Help!
