Symmetrical Geometry Constraint Between Two Lines - API
danijel.radenkovic
danijel.radenkovic
Hello Inventor Users,
I need a some advice for VBA to create symmetrical constraint using API.
I have found for coincident constraint but not for symetrical.
Thanks in advance.
Regards
Danijel
Inventor 2018/Windows 10 x64
If this information was helpful, please consider marking it as an Accepted Solution by using the Accept as Solution. Kudos are also gladly accepted.
danijel.radenkovic
Hello Everyone,
I have found a way,
Call xySketch.GeometricConstraints.AddSymmetry(oLine1, oLine2, oLine3)
where: oLine1 is a line on the left side on the screen, oLine2 is on the right side and oLine3 is construction line on the middle.
Regards
Danijel
