Свойства iProperties
dr.avon0
dr.avon0
Подскажите пожалуйста, как записать значение из столбца "КОЛ." спецификации сборки в свойства детали iProperties в строку "Project" во вкладке "Project" (см. рис.) Например как на рисунке: 650мм нужно записать в строку "Проект" при этом нужно удалить мм, и форматировать значение в 0,65.
WCrihfield
Hi @dr.avon0.  I do not fully understand your request, but the image does help some.  Even the image contains lots of text that I can not select, and can not translate, so I will have to make a few assumptions here.  It looks like you want to copy the 'total quantity' of a specific assembly component and write that as the value of that component's Project iProperty value.  Unfortunately, I do not even know how to create many of the language specific characters involved in their names while using an English keyboard.  So, I created an example iLogic code that you can review and test with.  This example is using 3 code routine blocks of code.  The 'Main' one is getting the current document, and if it is not an assembly, shows a message, then exits the code.  Then it gets the assembly's BOM (Bill of Material), and its 'structured' view of the BOM.  Then the second code routine block of code is called to run, and supplies it with the BOMRows collection, so it can 'recursively' iterate through them.  As it iterates through them, it calls the third code routine block of code to run on each BOMRow object.  When it gets to that last code routine, it first gets the 'total quantity' of that BOMRow.  Then it tries to get the Inventor.Document object which that BOMRow references.  Then it tries to write that total quantity as the value of that Document's 'Project' iProperty.  So, this will do that for every BOMRow, instead of just one specific BOMRow.  In order to change its functionality to only effect one specific BOMRow, you can include some code in that last block of code that checks the name of the component of that BOMRow, to see if it is the one you want to work with, then only allow it to proceed if it is a match.  I did not include many comments within the code, because I am not fluent in your language, so it would be of no use to you.
Sub Main
	Dim oADoc As AssemblyDocument = TryCast(ThisDoc.Document, Inventor.AssemblyDocument)
	If oADoc Is Nothing Then
		MsgBox("An Assembly Document must be active for this rule to work. Exiting.", vbCritical, "")
		Exit Sub
	Dim oBOM As Inventor.BOM = oADoc.ComponentDefinition.BOM
	oBOM.StructuredViewEnabled = True
	oBOM.StructuredViewFirstLevelOnly = True
	Dim oBOMView, oStrBOMView As BOMView
	For Each oBOMView In oBOM.BOMViews
		If oBOMView.ViewType = BOMViewTypeEnum.kStructuredBOMViewType Then
			oStrBOMView = oBOMView
			Exit For
	Next 'oBOMView
	If oStrBOMView Is Nothing Then
		MsgBox("Structured BOMView not found!", vbCritical, "iLogic")
		Exit Sub
	RecurseBOMRows(oStrBOMView.BOMRows, AddressOf ProcessBOMRow)
	MsgBox("Total Quantity found = " & oTotalQty, , "")
End Sub
Sub RecurseBOMRows(oBOMRows As Inventor.BOMRowsEnumerator, rowProcess As Action(Of Inventor.BOMRow))
	If (oBOMRows Is Nothing) OrElse (oBOMRows.Count = 0) Then Exit Sub
	For Each oRow As Inventor.BOMRow In oBOMRows
		'call other Sub routine to run on this BOMRow
		rowProcess(oRow)
		'recurse child BOMRows, if any
		If (Not oRow.ChildRows Is Nothing) Then
			RecurseBOMRows(oRow.ChildRows, rowProcess)
	Next
End Sub
Sub ProcessBOMRow(bomRow As Inventor.BOMRow)
	Dim sTotalQty As String = bomRow.TotalQuantity
	Dim oRowDoc As Inventor.Document = Nothing
	Try
		oRowDoc = bomRow.ComponentDefinitions.Item(1).Document
	Catch
	End Try
	If (oRowDoc Is Nothing) Then Exit Sub
	If (Not oRowDoc.IsModifiable) Then Exit Sub
	Try
		oRowDoc.PropertySets.Item(3).Item(3).Value = sTotalQty
	Catch
	End Try
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
dr.avon0
Привет. Я сделал более детальное изображение. Интересуют детали из генератора сварной конструкции, в сборке. Эти детали имеют размер в миллиметрах. Необходимо записать в столбец «Проект» их длину в метрах. Правило необходимо для всех новых деталей генератора сварной конструкции.
dr.avon0
here I tested the iLogic code. Where the number of components is 2, it was not possible to output 0.7 meters.
