Hi @arron.craig. I do not really use PointClounds much myself, but may be able to help some with come code to get you started towards your goal. Below is some code I just typed within an iLogic rule, designed to be used on a part. Right now it will only 'record/write' the PointCloud's name, source file, units factor, and offset in X, Y, & Z. You may be able to develop it further to get the 'rotation' data you are looking for from the transformation Matrix we get from the PointCloud. There is no simple, direct property for retrieving that data, so some 'interpretation' may need to be involved. Plus, I have no idea how you need all this information formatted, and have no use for any of it myself. There is a direct method for deleting the PointClound though (PointCloud.Delete). I did not include that at this point either, because I know more development will be needed in the 'report' portion of this before you will want to be deleting them.
Sub Main
Dim oPDoc As PartDocument = Nothing
'used if 'receiving' the Document from a 'RunRule' method with 'arguments'
'lets us use this rule like a Sub routine with 'input parameter(s)'
If RuleArguments.Exists("Document") Then
oPDoc = TryCast(RuleArguments.Value("Document"), Inventor.PartDocument)
Else
'used if no Document 'received'
oPDoc = TryCast(ThisDoc.Document, Inventor.PartDocument)
If oPDoc Is Nothing Then Return
Dim oPDef As PartComponentDefinition = oPDoc.ComponentDefinition
Dim oPtClouds As PointClouds = oPDef.PointClouds
If oPtClouds.Count = 0 Then Exit Sub
Dim oReport As New System.Text.StringBuilder()
oReport.AppendLine("PointClouds Report:")
For Each oPtCloud As PointCloud In oPtClouds
oReport.AppendLine("PointCloud Name = " & oPtCloud.Name)
oReport.AppendLine("SourceFullFileName = " & oPtCloud.SourceFullFileName)
oReport.AppendLine("UnitsFactor = " & oPtCloud.UnitsFactor.ToString())
Dim oTransform As Inventor.Matrix = oPtCloud.Transform
Dim oOffset As Inventor.Vector = oTransform.Translation
oReport.AppendLine("Offset X = " & oOffset.X.ToString())
oReport.AppendLine("Offset Y = " & oOffset.Y.ToString())
oReport.AppendLine("Offset Z = " & oOffset.Z.ToString())
oReport.AppendLine()
Next
WriteStringToTextFile(oReport.ToString(), "C:\Temp\PointClouds Report.txt", True)
End Sub
Sub WriteStringToTextFile(sStringToWrite As String, sTextFile As String, bLaunch As Boolean)
If sStringToWrite Is Nothing OrElse sStringToWrite = String.Empty Then Exit Sub
If sTextFile Is Nothing OrElse sTextFile = String.Empty Then Exit Sub
If System.IO.File.Exists(sTextFile) Then
System.IO.File.WriteAllText(sTextFile, sStringToWrite)
Else 'file does not already exist
Using oSW As System.IO.StreamWriter = System.IO.File.CreateText(sTextFile)
oSW.Write(sStringToWrite)
oSW.Close()
End Using
If bLaunch = True Then
Process.Start(sTextFile)
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
