SurfaceBody without Featues
wj
wj
Hello all,
is there a way to get surfaceBody without features without suppressing the features?
JelteDeJong
I'm not sure what you mean by getting a surface body and what you want to do with it. But it is possible to create a new feature with all the geometry of a surface body. have a look at this example:
Dim doc As PartDocument = ThisDoc.Document
Dim body As SurfaceBody = doc.ComponentDefinition.SurfaceBodies.Item(1)
Dim nonParamFeatures As NonParametricBaseFeatures = doc.ComponentDefinition.Features.NonParametricBaseFeatures
Dim nonParamDef As NonParametricBaseFeatureDefinition = nonParamFeatures.CreateDefinition
Dim tObjs As TransientObjects = ThisApplication.TransientObjects
Dim objs As ObjectCollection = tObjs.CreateObjectCollection
objs.Add(body)
nonParamDef.BRepEntities = objs
nonParamDef.OutputType = BaseFeatureOutputTypeEnum.kSolidOutputType
nonParamFeatures.AddByDefinition(nonParamDef)
Jelte de Jong
Blog: hjalte.nl - github.com
wj
Hello JelteDeJong,
thank you for the quick reply.
what I mean is:
E.g. I have here a cube that has been made into a triangle by the extrudions. (picture 1)
(picture 1)
If I suppress the extrusions, I get the original shape again. (picture 2)
(picture 2)
But how do I get the "original shape" (the cube) without suppressing the extrusions?
I need to get to the "invisible" faces.
Thanks in advance!
Michael.Navara
Generally it is not possible, because this object "doesn't exists" in current context of model. It exists in some point of model history, but not now.
I don't know why you need this faces.
Stakin
If you don't want other one know your design process,you can save it as "stp",and share the stp file to the other.
The stp file is without the sketch\features\Work features.
