iLogic: Find Parent of derived part with broken link in an assembly
fabimann
Message 1 of 9
fabimann
in an assembly I'm trying to find derived parts with a broken link. These should be listed to an Excel file along with the file name of the missing parent.
This is what I already figured out with the help of this forum. But now I'm struggeling to list the name of the parent as well:
Dim RefPartList, RefPartSourceList As New ArrayList()
Dim XLSXfolder, XLSXfileName, XLSXfile, XLSXtable As String
Dim XLSXrowBegin, XLSXrow As Integer
'Find derived parts with broken link to parent
Dim doc As AssemblyDocument = ThisDoc.Document
Dim partDefs = doc.AllReferencedDocuments.Cast(Of Document).
    Where(Function(refDoc) refDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject).
    Where(Function(refDoc) refDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Count <> 0).
    Where(Function(refDoc) refDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Item(1).LinkedToFile <> True).
    ToList()
For Each refDoc As PartDocument In partDefs
    RefPartList.Add(refDoc)
Next
'Add code here
'Excel Export
XLSXfolder = "C:\temp\"
XLSXfileName = "test.xlsx"
XLSXfile = XLSXfolder & XLSXfileName
XLSXtable = "Tabelle1"
XLSXrowBegin = 1
XLSXrow = XLSXrowBegin + 1
GoExcel.CellValue(XLSXfile, XLSXtable, "A" & XLSXrowBegin) = "Derived Part with missing reference to parent"
GoExcel.CellValue(XLSXfile, XLSXtable, "B" & XLSXrowBegin) = "Missing parent"
'Derived Part with missing reference to parent
For Each refDoc In RefPartList
	CellFileName = "A" & XLSXrow
	GoExcel.CellValue(XLSXfile, XLSXtable, CellFileName) = refDoc.DisplayName
	XLSXrow = XLSXrow + 1
Next
'Missing parent
For Each refDocMis In RefPartSourceList
	CellFileName = "B" & XLSXrow
	GoExcel.CellValue(XLSXfile, XLSXtable, CellFileName) = oParent
Next
GoExcel.Save
MessageBox.Show("Done", ":-)", MessageBoxButtons.OK, MessageBoxIcon.Asterisk, MessageBoxDefaultButton.Button1)
Any help is much appreciated. Have a merry Christmas.
Best regards
Fabian
Replies (8)
Message 2 of 9
Michael.Navara
Once the link to file is broken, you are not able to restore them and also read any information about them. Only DerivedPartComponent.Name remains (something like Part1.ipt)
Message 3 of 9
fabimann
Does DerivedPartComponent.Name refer to the the name of the parent? Not sure if that is described properly, I'm looking for the name of the parent or base-component as marked below. As the name is stated in the Inventor-browser I assume that it could be read out using iLogic or am I wrong?
Message 4 of 9
Ralf_Krieg
Hello
The DerivedPartComponent.Name is AFAIK the DisplayName of the part document. This can be the document name, but can also be something different. If you don't override the display name, it is the document name by default.
R. Krieg
RKW Solutions
www.rkw-solutions.com
Message 5 of 9
fabimann
Hello Michael,
thanks, I'll give it a try after the holidays.
Best regards
Fabian
Message 6 of 9
fabimann
Happy new year 🙂
So DerivedPartComponent.Name is the basically what I am looking for. I understand that it might not  state the actual filename, if the component has been renamed in the Inventor browser.
It might still be useful as a hint to look further into an error. So I'd also like to export that data into the Excel-tabel. Unfortunately I'm not able to do so, could you please help again and adapt the code above.
Fabian
Message 7 of 9
Ralf_Krieg
Hello
Did you find a solution? Sorry, I'm very late. Just lost focus on this thread.
One possible solution is to grab the filename out of the feature name.
break
    ToList()
Dim oRefFeature As ReferenceFeature
    'Add derived part to list
    'get reference feature in derived part (assuming there's just one)
	oRefFeature = refDoc.Componentdefinition.Features.ReferenceFeatures.Item(1)
    'Add missing file to list
	RefPartSourceList.Add( Split(oRefFeature.Name,":").Last)
Next
'Excel Export
XLSXfileName = "temp.xlsx"
XLSXrowBegin = 1
Next
'Missing parent
	GoExcel.CellValue(XLSXfile, XLSXtable, CellFileName) = refDocMis
Next
GoExcel.Save
R. Krieg
RKW Solutions
Message 8 of 9
fabimann
thanks for getting back on this topic. I tried to find a solution with your hints but was not able to get it to work. I will try your code after my holiday.
Thanks again
Fabian
Message 9 of 9
fabimann
Hello @Ralf_Krieg ,
sorry for my late reply, it took some time to catch up after the holidays. Unfortunately your code doesn't work with my assembly. I commented out parts of the code, it seems that one problems starts with:
oRefFeature = refDoc.ComponentDefinition.Features.ReferenceFeatures.Item(1)
Did the code work with your assembly, what could cause this error?
Thank you
Fabian
