Supress Features Issue
scottbudge
scottbudge
Hi All
I am having issues with the following code. The issue is, when the height is less than the width the code works as intended, but when the height is greater than the width the "Feature.IsActive("LeftBottomFace") = False" & "Feature.IsActive("RightBottomFace") = False" rules are being ignored. Any ideas as to why this is happening would be greatly appreciated.
Parameter("TopCut") = Parameter("UnderlapCut")
Parameter("TopFlange") = Parameter("UnderlapFlange")
Parameter("TopHoleSize") = 10
Parameter("BottomCut") = Parameter("OverlapCut")
Parameter("BottomFlange") = Parameter("OverlapFlange")
Parameter("BottomHoleSize") = 8
Parameter("LeftCut") = Parameter("UnderlapCut")
Parameter("LeftFlange") = Parameter("UnderlapFlange")
Parameter("LeftHoleSize") = 8
Parameter("RightCut") = Parameter("UnderlapCut")
Parameter("RightFlange") = Parameter("UnderlapFlange")
Parameter("RightHoleSize") = 10
Feature.IsActive("LeftTopFace") = True
Parameter("LTHoleSize") = 8
Feature.IsActive("RightTopFace") = True
Parameter("RTHoleSize") = 10
Feature.IsActive("TempFixR") = True
Feature.IsActive("TempFixL") = False
iProperties.Value("Custom", "Type") = "RECESSED FIX"
iProperties.Value("Custom", "Joint") = "INTER STARTER"
iProperties.Value("Custom", "Lay") = "L TO R"
InventorVb.DocumentUpdate()
A.Acheson
Hi @scottbudge
Do you have the pseudo logic laid out to switch the features on and off?
Regards
Alan
scottbudge
Hi Sorry I am new to this and self taught, what do you mean when you say "pseudo logic" ?
A.Acheson
Something like this? Do you have this logic built out to control your features?
If height <width Then
    Feature.IsActive("LeftBottomFace") = True
    Feature.IsActive("RightBottomFace") = True
ElseIf height >width Then
EndIf
Regards
Alan
scottbudge
I have something similar in my "Parameters" rule (see below), would it be better to incorporate as you have suggested?
If Parameter("Cassette_Width") > Parameter("Cassette_Height")
iProperties.Value("Custom", "Orientation") = "HORIZONTAL"
iProperties.Value("Custom", "ProgramHeight") = Parameter("Cassette_Height")
iProperties.Value("Custom", "ProgramWidth") = Parameter("Cassette_Width")
iProperties.Value("Custom", "Gauge") = Parameter("Thickness")
iProperties.Value("Custom", "Height") = Parameter("Cassette_Height")
iProperties.Value("Custom", "Width") = Parameter("Cassette_Width")
iProperties.Value("Custom", "StiffLength") = Parameter("Cassette_Height")-10
Length = SheetMetal.FlatExtentsLength
Girth = SheetMetal.FlatExtentsWidth
iProperties.Value("Custom", "Length")= Round(Length,1)
iProperties.Value("Custom", "Girth") = Round(Girth, 1)
iProperties.Value("Custom", "Depth") = Parameter("Depth")
iProperties.Value("Custom", "Path") = ThisDoc.Path
ElseIf Parameter("Cassette_Height") > Parameter("Cassette_Width")
iProperties.Value("Custom", "Orientation") = "VERTICAL"
iProperties.Value("Custom", "ProgramHeight") = Parameter("Cassette_Width")
iProperties.Value("Custom", "ProgramWidth") = Parameter("Cassette_Height")
iProperties.Value("Custom", "StiffLength") = Parameter("Cassette_Width")-10
ElseIf Parameter("Cassette_Width") = Parameter("Cassette_Height")
The above code is driven by this master code that reads an excel spreadsheet
'Dim exl As String
'exl = SharedVariable("exl")
xlspath = ThisDoc.Path & "/ORDER FORM.xlsx"
Dim oExcelRow As String
oExcelRow = iProperties.Value("Custom", "ExcelRow")
Dim oExcelRow2 As String
oExcelRow2 = oExcelRow + 1
iProperties.Value("Custom", "ExcelRow") = oExcelRow2
	'GoExcel.Open(sharedvariable("exl"))
'A = CASSETTE ID
'B = CASSETTE QTY
'C = CASSETTE WIDTH
'D = CASSETTE HEIGHT
'E = CASSETTE LENGTH
'F = CASSETTE GIRTH
'G = FACADE TYPE
'H = CASSETTE JOINT TYPE
'I = LAY DIRECTION
'K = CASSETTE DEPTH
'K = TOP HOLE CENTRES (A)
'L = BOTTOM HOLE CENTRES (A)
'M = MACHINE ROUTE
'N = SAP NO.
'O = LINE NO.
'P = NOTES
'Q = STIFFENERS
'// Cassette ID
iProperties.Value("Project", "Part Number") = GoExcel.CellValue(xlspath, "Sheet1","A" & iProperties.Value("Custom", "ExcelRow"))
If GoExcel.CellValue("A" & iProperties.Value("Custom", "ExcelRow")) = Nothing
	MessageBox.Show("CASSETTE NUMBER CELL BLANK", "Error")
	iProperties.Value("Project", "Part Number") = "ERROR"
'// Cassette Qty
iProperties.Value("Custom", "Qty") = GoExcel.CellValue(xlspath, "Sheet1","B" & iProperties.Value("Custom", "ExcelRow"))
If GoExcel.CellValue("B" & iProperties.Value("Custom", "ExcelRow")) = Nothing
	MessageBox.Show("CASSETTE QTY CELL BLANK", "Error")
	iProperties.Value("Custom", "Qty") = "ERROR"
'// Cassette Height
Parameter("Cassette_Height") = GoExcel.CellValue(xlspath, "Sheet1","D" & iProperties.Value("Custom", "ExcelRow"))
If GoExcel.CellValue("D" & iProperties.Value("Custom", "ExcelRow")) = Nothing
	MessageBox.Show("CASSETTE HEIGHT CELL BLANK", "Error")
	Parameter("Cassette_Height") = 600
'// Cassette Width
Parameter("Cassette_Width") = GoExcel.CellValue(xlspath, "Sheet1","C" & iProperties.Value("Custom", "ExcelRow"))
If GoExcel.CellValue("C" & iProperties.Value("Custom", "ExcelRow")) = Nothing
	MessageBox.Show("CASSETTE WIDTH CELL BLANK", "Error")
	Parameter("Cassette_Width") = 600
'// Cassette Depth
iProperties.Value("Custom", "Depth") = GoExcel.CellValue(xlspath, "Sheet1","K" & iProperties.Value("Custom", "ExcelRow"))
Parameter("Depth2") = iProperties.Value("Custom", "Depth")+1
'// Cassette Joint Type
iProperties.Value("Summary", "Title") = GoExcel.CellValue(xlspath, "Sheet1","H" & iProperties.Value("Custom", "ExcelRow"))
If  iProperties.Value("Summary", "Title") = "Bottom Starter"
		iProperties.Value("Custom", "Type") = "BOTTOM STARTER"
	ElseIf iProperties.Value("Summary", "Title") = "Bottom Intermediate"
		iProperties.Value("Custom", "Type") = "BOTTOM INTERMEDIATE"
	ElseIf iProperties.Value("Summary", "Title") = "Bottom End"
		iProperties.Value("Custom", "Type") = "BOTTOM END"
	ElseIf iProperties.Value("Summary", "Title") = "Inter Starter"
		iProperties.Value("Custom", "Type") = "INTERMEDIATE STARTER"
	ElseIf iProperties.Value("Summary", "Title") = "Intermediate"
		iProperties.Value("Custom", "Type") = "INTERMEDIATE"
	ElseIf iProperties.Value("Summary", "Title") = "Inter End"
		iProperties.Value("Custom", "Type") = "INTERMEDIATE END"
	ElseIf iProperties.Value("Summary", "Title") = "Top Starter"
		iProperties.Value("Custom", "Type") = "TOP STARTER"
	ElseIf iProperties.Value("Summary", "Title") = "Top Intermediate"
		iProperties.Value("Custom", "Type") = "TOP INTER"
	ElseIf iProperties.Value("Summary", "Title") = "Top End"
		iProperties.Value("Custom", "Type") = "TOP END"
	ElseIf GoExcel.CellValue(xlspath, "Sheet1","G" & iProperties.Value("Custom", "ExcelRow")) = Nothing
	MessageBox.Show("CASSETTE TYPE CELL BLANK", "Error")
	iProperties.Value("Summary", "Title") = "ERROR"
'// Cassette Lay Direction
iProperties.Value("Custom", "Lay") = GoExcel.CellValue(xlspath, "Sheet1","I" & iProperties.Value("Custom", "ExcelRow"))
'//Bottom Starter
	If iProperties.Value("Custom", "Lay") = "L to R"
	iLogicVb.RunRule("BS-LtoR")
	ElseIf iProperties.Value("Custom", "Lay") = "R to L"
	iLogicVb.RunRule("BS-RtoL")
	ElseIf iProperties.Value("Custom", "Lay") = Nothing
	MessageBox.Show("LAY DIRECTION CELL BLANK", "Error")
	iProperties.Value("Custom", "Lay") = "ERROR"
	iLogicVb.RunRule("RESET")
'//Bottom Inter
	iLogicVb.RunRule("BI-LtoR")
	iLogicVb.RunRule("BI-RtoL")
'//Bottom End
	iLogicVb.RunRule("BE-LtoR")
	iLogicVb.RunRule("BE-RtoL")
'//Inter Starter
	iLogicVb.RunRule("IS-LtoR")
	iLogicVb.RunRule("IS-RtoL")
'//Intermediate
	iLogicVb.RunRule("II-LtoR")
	iLogicVb.RunRule("II-RtoL")
'//Inter End
	iLogicVb.RunRule("IE-LtoR")
	iLogicVb.RunRule("IE-RtoL")
'//Top Starter
	iLogicVb.RunRule("TS-LtoR")
	iLogicVb.RunRule("TS-RtoL")
'//Top Inter
	iLogicVb.RunRule("TI-LtoR")
	iLogicVb.RunRule("TI-RtoL")
'// Top End
	iLogicVb.RunRule("TE-LtoR")
	iLogicVb.RunRule("TE-RtoL")
'// NO TYPE
ElseIf iProperties.Value("Summary", "Title") = "ERROR"
''// Top Hole Centres
'Parameter("TopHoleGap") = GoExcel.CellValue(xlspath, "Sheet1","K" & iProperties.Value("Custom", "ExcelRow"))
''// Bottom Hole Centres
'Parameter("BottomHoleGap") = GoExcel.CellValue(xlspath, "Sheet1","K" & iProperties.Value("Custom", "ExcelRow"))
''// Left Hole Centres
'Parameter("LeftHoleGap") = GoExcel.CellValue(xlspath, "Sheet1","L" & iProperties.Value("Custom", "ExcelRow"))
''// Right Hole Centres
'Parameter("RightHoleGap") = GoExcel.CellValue(xlspath, "Sheet1","L" & iProperties.Value("Custom", "ExcelRow"))
'// Flat Pattern Extents
'//Vertical Cassette
If Parameter("Cassette_Height") >= Parameter("Cassette_Width")
iProperties.Value("Custom", "Girth") = Round(Length, 1)
iProperties.Value("Custom", "Length") = Round(Girth, 1)
GoExcel.CellValue(xlspath, "Sheet1","E" & iProperties.Value("Custom", "ExcelRow")) = iProperties.Value("Custom", "Length")
GoExcel.CellValue(xlspath, "Sheet1","F" & iProperties.Value("Custom", "ExcelRow")) = iProperties.Value("Custom", "Girth")
'//Horizontal Cassette
Else
iProperties.Value("Custom", "Length") = Round(Length, 1)
'// Other Stuff
iProperties.Value("Custom", "Machine Route") = GoExcel.CellValue(xlspath, "Sheet1", "M" & iProperties.Value("Custom", "ExcelRow"))
iProperties.Value("Custom", "SAP Order No.") = GoExcel.CellValue(xlspath, "Sheet1", "N" & iProperties.Value("Custom", "ExcelRow"))
iProperties.Value("Custom", "LineNo.") = GoExcel.CellValue(xlspath, "Sheet1", "O" & iProperties.Value("Custom", "ExcelRow"))
iProperties.Value("Custom", "Stiffened") = GoExcel.CellValue(xlspath, "Sheet1", "T" & iProperties.Value("Custom", "ExcelRow"))
If iProperties.Value("Custom", "Stiffened") = "Stiffened"
iProperties.Value("Custom", "StiffQty") = GoExcel.CellValue(xlspath, "Sheet1", "U" & iProperties.Value("Custom", "ExcelRow")) * iProperties.Value("Custom", "Qty")
ElseIf iProperties.Value("Custom", "Stiffened") = "Un-Stiffened"
iProperties.Value("Custom", "StiffQty") = 0
GoExcel.Save
iLogicForm.Show("NextCassette")
scottbudge
I found the issue, a pattern feature was relying on the feature I wanted to suppress so I simply selected a different axis for my direction and it solved the problem.
