Rules for hiding the circle of tab countsink
tkddud711
Message 1 of 21
tkddud711
hello?
This is a post I made previously on the forum.
https://forums.autodesk.com/t5/inventor-programming-ilogic/please-tell-me-how-to-make-tab-countsink-...
There are two things I want to change in the code below.
1. The count sink holes of the tab’s circular pattern, square pattern, and linked pattern are not hidden.
2. In the drawing, the rule is applied to the first view of the sheet, but I want to select the view to apply it.
Can you help me?
Sub Main()
    Dim drawing As DrawingDocument = ThisDoc.Document
    Dim drawingView As DrawingView = drawing.ActiveSheet.DrawingViews(1)
    Dim part As PartDocument = drawingView.ReferencedDocumentDescriptor.ReferencedDocument
    Dim partDef As PartComponentDefinition = part.ComponentDefinition
    For Each holeFeature As HoleFeature In partDef.Features.HoleFeatures
        If holeFeature.HoleType <> HoleTypeEnum.kCounterSinkHole Then Continue For
        'Get the biggest circles of holeFeature in drawing view
        Dim biggestCircles As New List(Of DrawingCurveSegment)
        Dim biggestCircleRadius As Double = 0
        Dim holeDrawingCurves = drawingView.DrawingCurves(holeFeature)
        For Each holeDrawingCurve As DrawingCurve In holeDrawingCurves
            For Each drawingCurveSegment As DrawingCurveSegment In holeDrawingCurve.Segments
                Dim circle2d = TryCast(drawingCurveSegment.Geometry, Circle2d)
                If circle2d Is Nothing Then Exit For
                If circle2d.Radius > biggestCircleRadius Then
                    biggestCircles.Clear()
                    biggestCircleRadius = circle2d.Radius
                    biggestCircles.Add(drawingCurveSegment)
                ElseIf circle2d.Radius = biggestCircleRadius Then
            Next
        Next
        'Hide
        For Each biggestCircle As DrawingCurveSegment In biggestCircles
            biggestCircle.Visible = False
        Next
    Next
End Sub
Replies (20)
Message 2 of 21
yuzeaa
Sub Main()
    Dim drawingView As DrawingView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select View")
	If drawingView Is Nothing Then return
    Dim holeFeatureList As New List(Of HoleFeature)
	Dim PatternFeatureList As New List(Of PartFeature)
        If HoleFeature.HoleType <> HoleTypeEnum.kCounterSinkHole Then Continue For
		holeFeatureList.Add(HoleFeature)
    Next
	For Each RecPatternFeature As RectangularPatternFeature In partDef.Features.RectangularPatternFeatures
		If RecPatternFeature.ParentFeatures.Cast(Of PartFeature).Any(Function(item) holeFeatureList.Contains(item)) Then
			PatternFeatureList.Add(RecPatternFeature)
    Next
	For Each CirclePatternFeature As CircularPatternFeature In partDef.Features.CircularPatternFeatures
		If CirclePatternFeature.ParentFeatures.Cast(Of PartFeature).Any(Function(item) holeFeatureList.Contains(item)) Then
			PatternFeatureList.Add(CirclePatternFeature)
    Next
	For Each PatternFeature In PatternFeatureList
		hideCurveByFeature(PatternFeature,drawingView)
	Next
	For Each holeFeature In holeFeatureList
		hideCurveByFeature(HoleFeature,drawingView)
	Next
End Sub
Sub hideCurveByFeature(oFeature As PartFeature,oView As DrawingView)
	    Dim DrawingCurves As DrawingCurvesEnumerator = oView.DrawingCurves(oFeature)
		Dim DrawingCurveSegmentList As List(Of DrawingCurveSegment) = DrawingCurves.Cast(Of DrawingCurve).SelectMany(Of DrawingCurveSegment)(Function(DrawingCurve) DrawingCurve.Segments.Cast(Of DrawingCurveSegment)).ToList()
        DrawingCurveSegmentList = DrawingCurveSegmentList.Where(Function(x) x.GeometryType = kcirclecurve2d).ToList
		biggestCircles =  DrawingCurveSegmentList.GroupBy(Function(item) Round(item.Geometry.Radius,5)).OrderByDescending(Function(Group) Group.Key).First
        For Each Circle As DrawingCurveSegment In biggestCircles
             If Circle.Visible = True Then
			 Else
        Next
End Sub
Message 3 of 21
tkddud711
Thank you for your reply.
Everything works perfectly, but it doesn't apply to sketch driven patterns.
Is it possible?
Message 4 of 21
yuzeaa
This will work.
Sub Main()
    Next
    Next
    Next
	For Each SketchPatternFeature As SketchDrivenPatternFeature In partDef.Features.SketchDrivenPatternFeatures
		If SketchPatternFeature.Definition.ParentFeatures.Cast(Of PartFeature).Any(Function(item) holeFeatureList.Contains(item)) Then
			PatternFeatureList.Add(SketchPatternFeature)
    Next
	Next
	Next
End Sub
			 Else
        Next
End Sub
Message 5 of 21
tkddud711
A problem arose.
Only countsink for tabs should work.
It also works on countsink hole.
Is it possible to make only the tab's countsink work?
I have attached the test file.
Message 6 of 21
tkddud711
A problem arose.
And if you select a top view, front view, or back view, an error occurs on line 39.
Message 7 of 21
yuzeaa
I don't quite understand you, and I can't open the attachment either. I am using Inventor 2020.
Message 8 of 21
tkddud711
This is the version inventor 2018 file.
I ran it in all views as shown in the picture, but an error occurred.
You must pass the countsink marked with a cloud in the photo.
Message 9 of 21
yuzeaa
Sub Main()
	If drawingView Is Nothing Then Return
		If HoleFeature.HealthStatus <> kUpToDateHealth Then Continue For
		If HoleFeature.IsClearanceHole Then Continue For
    Next
    Next
    Next
    Next
	Next
	Next
End Sub
		If DrawingCurveSegmentList.Count = 0 Then Return
			 Else
        Next
End Sub
Message 10 of 21
tkddud711
Thank you for your continued attempts to provide the correct answer.
I think we're almost there.
Lastly, you need to hide the arc of the tab on the back as shown in the picture.
Running the rule hides the inner diameter circle.
And the rules should apply to MirrorFeature as well.
Can I change it?
Message 11 of 21
yuzeaa
It is easy to get there.
Sub Main()
    Next
    Next
    Next
    Next
	Next
	Next
End Sub
    DrawingCurveSegmentList = DrawingCurveSegmentList.Where(Function(x) x.GeometryType = kcirclecurve2d OrElse x.GeometryType = kCircularArcCurve2d).ToList
	DrawingCurveSegmentList.RemoveAll(Function(x) x.Parent.ModelGeometry.Type = kFaceobject)
		 Else
    Next
End Sub
Message 12 of 21
tkddud711
Does not apply to mirror features.
The file MirrorFeature_test5.ipt is attached to the above article.
Is it possible?
Message 13 of 21
yuzeaa
Including MirrorFeatures.
Sub Main()
    Next
    Next
    Next
    Next
	For Each MirFeature As MirrorFeature In partDef.Features.MirrorFeatures
		If MirFeature.ParentFeatures.Cast(Of PartFeature).Any(Function(item) holeFeatureList.Contains(item)) Then
			PatternFeatureList.Add(MirFeature)
    Next
	Next
	Next
End Sub
		 Else
    Next
End Sub
Message 14 of 21
tkddud711
In the MirrorFeature_test5.ipt file:
Mirrored tabs as shown below are not applied.
I think it will be of great help to me once I complete this.
Message 15 of 21
yuzeaa
Grouping curves by center point to handle different holes.
Sub Main()
	Dim PatternorMirFeatureList As New List(Of PartFeature)
    Next
			PatternorMirFeatureList.Add(RecPatternFeature)
    Next
			PatternorMirFeatureList.Add(CirclePatternFeature)
    Next
			PatternorMirFeatureList.Add(SketchPatternFeature)
    Next
			PatternorMirFeatureList.Add(MirFeature)
    Next
	For Each PatternFeature In PatternorMirFeatureList
	Next
	Next
End Sub
    biggestCircles = DrawingCurveSegmentList.GroupBy(Function(item) Round(item.Geometry.Center.X,5) & Round(item.Geometry.Center.Y,5)).Select(Function(Group) Group .OrderByDescending(Function(item) item.Geometry.Radius).First()).ToList()
		 Else
    Next
End Sub
Message 16 of 21
tkddud711
Message 17 of 21
tkddud711
Works so perfectly!
You have freed me from the pain of my work!
Thank you for your hard work.
Message 18 of 21
tkddud711
hello~
I took a break over the weekend and applied the rules today, but a problem occurred.. ㅜㅡㅜ
When mirroring an extrusion or cut, an error occurs at line 30.
Modeling is attached.
Is it possible to fix the error?
Message 19 of 21
yuzeaa
Replace the following code.
		If MirFeature.ParentFeatures.Oftype(Of HoleFeature).Any(Function(item) holeFeatureList.Contains(item)) Then
    Next
Message 20 of 21
yuzeaa
I found more issues with the same reason in pattern features.
		If RecPatternFeature.ParentFeatures.Oftype(Of HoleFeature).Any(Function(item) holeFeatureList.Contains(item)) Then
    Next
		If CirclePatternFeature.ParentFeatures.Oftype(Of HoleFeature).Any(Function(item) holeFeatureList.Contains(item)) Then
    Next
		If SketchPatternFeature.Definition.ParentFeatures.OfType(Of HoleFeature).Any(Function(item) holeFeatureList.Contains(item)) Then
    Next
    Next
