Supress and unsupressing constraints in Ilogic
sebastiaan_kauffeld
sebastiaan_kauffeld
First I will say I am a complete iLogic newbie just trying to experiment so I'm probably missing something basic. I have tried to supress and unsupress constraints by using this tutorial (https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2015...).
In my example I want to move a motor to the other side of the transport, so I have created two constraints in my assembly and supressed one of them manualy. Now I want to use a Ilogic rule to supress the other constraint and unsupress the manualy supressed constraint. I have tried to use the code descriped in the tutorial, but nothing happens. Can someone explain me what I am doing wrong?
Sergio.D.Suárez
Hi, what happens is that for that code to work, you should have a user parameter created by you, called "ConfigStyle" with the values A, and B.
You can create the parameter as follows.
In the example you show this would be the condition sought to perform the task.
I await your tests and comments.
I hope this helps with your problem. Cheers
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
