suppression
suppression
SpokenEarth
suppression
SpokenEarth
Hi, I have an assembly with two parts.
I'm trying to suppress the part shaft and the feature hole from the part plate at the same time within the assembly and control the suppression with a Boolean true/false parameter.
Can anyone help?
Andrii_Humeniuk
Hi @SpokenEarth . You need to add a user parameter as in the screenshot:
And this iLogic code:
Component.IsActive("shaft:1") = Not b_Suppr
Feature.IsActive("plate:1", "hole") = not b_Suppr
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
SpokenEarth
Thank you Andrii
