Suppressing Views in an .idw
ASchlaack
Message 1 of 9
ASchlaack
I'm currently running a rule:
If Parameter("15-1-0000.iam.Length_1") <= 60 Then
	ActiveSheet.View("VIEW69").View.Suppressed = True
End If
 *that's not the whole rule but it's enough to get the point...
 But unless I'm on the sheet that view is on (Sheet 15) I get this error:
How can I change the rule to work no matter what sheet I'm on when the rule is fired?
Aaron Schlaack
Autodesk Inventor 2018
Dell Windows 8.1 64 bit Intel(R) Xeon(R) @ 3.50GHz 32GB Ram
Replies (8)
Message 2 of 9
bretrick30
The code you are using will only access the views on the Active Sheet.  To do what you are looking for, you will need to loop through the sheets and the views on each sheet to find the one you want to suppress.
SyntaxEditor Code Snippet
oDoc = ThisDoc.Document
Dim oSheet As Sheet
For Each oSheet In oDoc.Sheets
    Dim oView As DrawingView
    For Each oView In oSheet.DrawingViews
        If oView.Name = "VIEW69" Then
            oView.Suppressed = True
        End If
    Next
Next
Using this you can also suppress any other views by either doing an if statement with an Or:
If oView.Name = "VIEW69" Or oView.Name = "VIEW70" Or oView.Name = "VIEW71" Then
End If
Or by doing a Select Case:
Select Case oView.Name
    Case "VIEW69","VIEW70","VIEW71"
End Select
Message 3 of 9
ASchlaack
I'd like to do the case one, how do I program in the varibles? Right now they are If then statements.
Aaron Schlaack
Message 4 of 9
bretrick30
You can put the whole loop inside of an If Statement.  I'm assuming you will want an else to that if statement for when the value is not less than or equal to 60 it will turn those views back on.
Dim oSheet As Sheet
            End Select
        Next
    Next
Else
                    oView.Suppressed = False
            End Select
        Next
    Next
End If
Message 5 of 9
ASchlaack
Well without trying to be too complicated, I have 4 varibles...
Else If Parameter("15-1-0000.iam.Length_1") > 60 in And Parameter("15-1-0000.iam.Length_1") <= 120 in Then
Else If Parameter("15-1-0000.iam.Length_1") > 120 in And Parameter("15-1-0000.iam.Length_1") <= 180 in Then
Else If Parameter("15-1-0000.iam.Length_1") > 180 in Then
 And I have 12 different things that get supressed and unsurpressed at different times... I don't want to make you have to do huge amounts of work for me but could you show me how I can do the else if using cases if that's possible please?
Aaron Schlaack
Message 6 of 9
bretrick30
Select Case Parameter("15-1-0000.iam.Length_1")
    Case 60 To 120
        'Enter Code Here
    Case 121 To 180
        'Enter Code Here
    Case >180
        'Enter Code Here
    Case Else
        'This will be when it is under 60
'If it will never be under 60 you dont have to use this. I like having all cases covered. End Select
Message 7 of 9
ASchlaack
Thank you for your help so much and I'm sorry to be a pain but since these parts will turn on and off because my length will checnge I'd need to say if it's surpressed or unsupressed in each case correct? I can't get a way to get this to work. Here's my current code that works but only if I'm on the right sheet:
	ActiveSheet.View("VIEW70").View.Suppressed = True
	ActiveSheet.View("VIEW72").View.Suppressed = True
	ActiveSheet.View("VIEW73").View.Suppressed = True
	ActiveSheet.View("VIEW69").View.Suppressed = False
	ActiveSheet.View("VIEW70").View.Suppressed = False
	ActiveSheet.View("VIEW72").View.Suppressed = False
	ActiveSheet.View("VIEW73").View.Suppressed = False
End If
Aaron Schlaack
Message 8 of 9
bretrick30
Well, there are a few ways to do this.  I was trying to decide which way would be best.  This one is simplest I think.
Dim oSheet As Sheet
    Case <= 60
                    Case "VIEW69"
                    Case "VIEW70"
                    Case "VIEW72"
                    Case "VIEW73"
                End Select
            Next
        Next
    Case <= 120
                    Case "VIEW69"
                    Case "VIEW70"
                    Case "VIEW72"
                    Case "VIEW73"
                End Select
            Next
        Next
    Case <= 180
                    Case "VIEW69"
                    Case "VIEW70"
                    Case "VIEW72"
                    Case "VIEW73"
                End Select
            Next
        Next
    Case > 180
                    Case "VIEW69"
                    Case "VIEW70"
                    Case "VIEW72"
                    Case "VIEW73"
                End Select
            Next
        Next
End Select
Message 9 of 9
ASchlaack
Awesome!! Thank you so much for all of your help!
Aaron Schlaack
