Suppress Feature using a Range
I need to be able to suppress a feature in a part using a range. I've looked at the property of a feature and I can only select a single operation (>, <, etc.). I've tried writing some code but I'm getting an error. I would appreciate any help on the code or another way to suppress a feature in a range.
Public Function SupHole(CASE_HT As Double) As Double
CASE_HT = CASE_HT / 2.54
Dim oDoc As PartDocument
Dim oFeat As PartFeature
Set oFeat = oDoc.ComponentDefinition.Features("Hole22")
If CASE_HT > 109 And CASE_HT < 89 Then
oFeat.Suppressed = True
End If
End Function
Thanks for any help
Chris
alewer
First of all, when I glance at your code, I notice that you will never supress the feature, as CASE_HT cannot be both greater than 109 and less than 89. You need to replace the "And" with "Or."
Edit: At second glance, I see that this is one of several problems with your code. You initialize but do not set oDoc (for example, "Set oDoc = ThisApplication.ActiveDocument"), your function returns nothing (should return a value or be a sub). You also divide by 2.54, which suggests a units conversion, in which case you should probably be using unitsofmeasure. I suggest you work through some of the example files in programming help.
You can probably do this without VBA by using sign(). There is a tutorial out there somewhere, but I can't seem to dig it up. I'll try to explain instead... Create a parameter that will be used to control the feature's suppression. The parameter equation, for your example, should read something like: sign(89.0001 ul - d0 / 1 in) + sign(d0 / 1 in - 108.9999 ul). If it returns a nonzero value, supress the feature. I've attached an example (2010) part. Edited by: alewer on Sep 4, 2009 1:57 PM
Thanks for your help. Using the sign() solved my problem. That's a very clever idea. If you ever find the tutortial on it, I'd like to read it. The code I posted had been changed to try and solve an error I was getting. Orginally it had Set oDoc = ThisApplication.ActiveDocument. Listed below is the code I orginally started with. I get an error on Set oDoc = ThisApplication.ActiveDocument. I added the Inventor references thru Tools/References but I still get the error. I've listed the code below. If you see something really wrong with it, I would appreciate your comments. Finally, you mentioned about / 2.54. I have to do this because Inventor is in metric and I need to convert it to decimal.
Dim oCompDef As PartComponentDefinition
Set oCompDef = oDoc.ComponentDefinition
If CASE_HT > 109 Or CASE_HT < 89 Then
End If
End Function
Thanks again for your help,
Chris
Using the sign()
tutorial on it, I'd like to read it.
See attached.
You've written this as a function, but I don't
know why.  Nowhere in your code do you return a value for the
function.  I'm guessing that you're trying to use this as an expression in
a parameter, like d2=VBA:SupHole(16).  If so, you
can't do that.  You're forbidden from accessing the Inventor API in a VBA
function.  This is covered very well in the Inventor API
documentation.
2.54.
It is considered very bad practice to perform
your own unit conversion with respect to programming Inventor.  The
Inventor API already provides a UnitsOfMeasure object that, among other things,
can convert units for you.  However, if I'm right about you trying to use
this as a VBA expression for a parameter, you can't access the
UnitsOfMeasure object for the aforementioned reason.  It would actually be
better to use the line of code
    If CASE_HT
> 276.86 or CASE_HT < 226.06 Then
thus doing the comparison in Inventor's native
centimeters.
brian r.
iwaskewycz
style="FONT-SIZE: 14pt; FONT-FAMILY: Verdana">inventor
specialist
Thanks for the reply. The goal of the function was to set the suppress flag if a certain condition was meet and when the part was updated, it would be suppressed. That's why it didn't return a value. That was one reason I took out the Set oDoc = active part because I knew the part was active. I will keep reading up on it. It would be nice if a VBA/Inventor book existed, but I have not found one yet.
Thanks for the pdf file, unfortunally when I try to open it, it saids the file is damaged and cannot be opened. Here is my email address c.riley@mtcworldwide.com. If you get a chance, I would appreciate it if you could email the file or reattach it to a reply.
Chris
brian r.
iwaskewycz
specialist
href="http://www.corefurnace.com/">core furnace systems
Well, I'd sure like to know what the cause of my
apparent inability to post a PDF is.
brian r.
iwaskewycz
specialist
style="FONT-SIZE: 14pt; FONT-FAMILY: Verdana">core furnace
systems
