Suppress Feature if it has no effect
Josh_Hudson97
Josh_Hudson97
Hi, I am after some code that will suppress a feature if it takes no effect after the rest of my logic has run....
I have a square box section post and users can choose to add drilling on each of the 4 face independently. If a user picks to have 3 drillings in a face then picks the opposite face to also have 3 drillings in I want to suppress any features that have no effect. i.e if Drilling positions are the same in opposite face suppress one of them.
I could do this long hand with logic, but hoping someone knows a way I could solve this with a few lines easily 😆
If I've helped you out drop the post a like, if I've given you a solution mark as solved. It's us, 'The community' that makes this place work 😄
FINET_Laurent
Hi @Josh_Hudson97,
Here a part with an extrusion (Extrusion1) (removing material) which has no effect :
You could use the folowing code to suppress it :
Dim doc As Inventor.PartDocument = ThisApplication.ActiveDocument
Dim pcd As Inventor.PartComponentDefinition = doc.ComponentDefinition
For Each f As Inventor.PartFeature In pcd.Features
	If f.HealthStatus = HealthStatusEnum.kDriverLostHealth Then f.Suppressed = True
Next
Does this suits your needs ?
Kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
Josh_Hudson97
Hi @FINET_Laurent,
Perfect thank you!
Funny enough I'd just found the solution on another post and was about to link it in here.
https://forums.autodesk.com/t5/inventor-forum/ilogic-to-detect-features-with-errors/td-p/6297950
