Ilogic to detect features with errors
JorisSteurs1246
JorisSteurs1246
Some features in my part  give me sometimes an error because they didn't change the geometry.
This behaviour is intended.
What I would like to do is to detect the error with iLogic, so that when the error happens I can suppress the feature.
Is that possible ?
Have a look at the screenshot attached.
thanks
Joris
Curtis_Waguespack
Hi  JorisSteurs1246,
See this link:
https://forums.autodesk.com/t5/inventor-customization/ilogic-to-count-features-without-including-tho...
I hope this helps.
Curtis
JorisSteurs1246
Hi  Curtis,
That link seemed  to have all the info I need and derived the code below from it.
SyntaxEditor Code Snippet
For Each oFeature As PartFeature In ThisDoc.Document.ComponentDefinition.Features
If oFeature.HealthStatus = HealthStatusEnum.kBeyondStopNodeHealth Then
oFeature.Suppressed = True
Next
But unfortunatly that didn't work
J.
Curtis_Waguespack
Hi JorisSteurs1246,
I think you want to use kInErrorHealth rather than kBeyondStopNodeHealth.
Of you might use kUpToDateHealth , something like this:
If oFeature.HealthStatus <> HealthStatusEnum.kUpToDateHealth Then ...
Also just as a tip, you can search and ask programming questions of this type on the Inventor Customization forum too:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
HealthStatusEnum Enumerator
Description
Constants signifying the state of the Object.
Methods
Name Value Description
kBeyondStopNodeHealth 11785 Object is beyond stop node in the browser.
kCannotComputeHealth 11783 Object cannot be evaluated.
kDeletedHealth 11782 Object has been destroyed. You may be holding on to an empty 'shell' of the Object.
kDriverLostHealth 11780 Object is driven by data from other Object(s), and one or more of them have been disconnected.
kInconsistentHealth 11786 Object is inconsistent with another object.
kInErrorHealth 11781 Object's internal state is in error.
kInvalidLimitsHealth 11789 Object has bad limits. e.g. max < min.
kJointDOFLockedHealth 11790 Object is locked Joint.
kNewlyAddedHealth 11788 Object is newly added or unsuppressed and has not been solved yet.
kOutOfDateHealth 11779 Object needs to be recomputed with respect to its 'driver(s)'.
kRedundantHealth 11787 Object's solution is redundant with another object.
kSuppressedHealth 11784 Object has been suppressed.
kUnknownHealth 11777 Object's status is not known.
kUpToDateHealth 11778 Object is up to date.
JorisSteurs1246
Hi Curtis,
Thank you that helped me a lot .  The other methods can come in handy also.
Can you point me to the place where you got these methods from?
Very likely there is more useful stuff for me to learn about.
Thanks again
Joris
Curtis_Waguespack
Hi JorisSteurs1246,
You can find this in the Programming help files. If you look in the Help pull down it will look something like this image.
I hope this helps.
Curtis
