Suppress component in a pattern by clicking
tomislav.peran
tomislav.peran
@J-Camper
I saw on the following link an interesting code on how to suppress components by clicking.
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/ilogic-suppress-component/td-p/10072...
Sub Main
	If ThisApplication.ActiveDocumentType <> kAssemblyDocumentObject Then MessageBox.Show("This rule is designed to only work in assembly documents.", "Wrong Document Type") : Exit Sub
	Dim PickLeafOC As ComponentOccurrence = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, "Select a Component to Supress")
	If IsNothing(PickLeafOC) Then Exit Sub ' If nothing gets selected then we're done
	PickLeafOC.Suppress()
End Sub
Is there a way to suppress a component that is in a pattern?
Tom
SevInventor
sorry misunderstood the question
tomislav.peran
Hi SevInventor
I tested the code this morning and it did not work. Now it works. I am not sure what happened.
Do you know by any chance how to repeat this command so that it is not necessary to click the rule every time?
Tom
tomislav.peran
To have the code repeating itself:
Do
Loop
 I will double-test things next time before posting.
Tom
SevInventor
Sub Main
	here:
	GoTo here
End Sub
tomislav.peran
Hi Sev,
Super. I do not have to remove Sub Main then.
Tom
