Suppress and Unsupress folder in the Assembly
karram
Message 1 of 10
karram
In my Assembly model i had two folder name like "Right pads" and " Left pads".
I have a condition like below.
If Baffle_Wall = "Right" Then
"Right pad" folder suppress
"Left pad" folder Unsuppress
If Baffle_Wall = "Left" Then
"Right pad" folder Unsuppress
"Left pad" folder suppress
If Baffle_Wall = "NO" Then
Below is ilogic code, but this will not works properly as per above condition. can you please guide or any other alternate code . Thanks
Sub Main()
  Dim oDoc As AssemblyDocument
  oDoc = ThisApplication.ActiveDocument
  Dim oPane As BrowserPane
  oPane = oDoc.BrowserPanes("Model")
  Dim oTopNode As BrowserNode
  oTopNode = oPane.TopNode
  Dim oFolder As BrowserFolder
  oFolder = oTopNode.BrowserFolders.Item("Right pads")
   Call SuppressFolder(oFolder)
   oFolder = oTopNode.BrowserFolders.Item("Left pads")
   Call UnSuppressFolder(oFolder)
  ElseIf Baffle_Wall = "Left" Then
   ElseIf Baffle_Wall = "NO" Then
  End Sub
' Recursive function as there could be subfolders too
Sub SuppressFolder(oFolder As BrowserFolder)
  Dim oItem As BrowserNode
  For Each oItem In oFolder.BrowserNode.BrowserNodes
    Dim oObj As Object
    oObj = oItem.NativeObject
    If TypeOf oObj Is BrowserFolder Then
      Call SuppressFolder(oObj)
    ElseIf TypeOf oObj Is ComponentOccurrence Then
      Dim oOcc As ComponentOccurrence
      oOcc = oObj
      If Not oOcc.Suppressed Then Call oOcc.Suppress (True)
    ElseIf TypeOf oObj Is OccurrencePattern Then
      Dim oPatt As OccurrencePattern
      oPatt = oObj
      Dim oElem As OccurrencePatternElement
      For Each oElem In oPatt.OccurrencePatternElements
        For Each oOcc In oElem.Occurrences
        Next
      Next
  Next
End Sub
Sub UnSuppressFolder(oFolder As BrowserFolder)
    Dim oObj As Object
      oOcc = oObj
      If Not oOcc.Suppressed Then Call oOcc.Suppress (False)
      oPatt = oObj
        Next
      Next
  Next
End Sub
Replies (9)
Message 2 of 10
_dscholtes_
    Dim oObj As Object
Yeah, I think there's a typo in the last line of code in the quote above. Just compare it with the name of the sub 😉 (sub is called UnSuppressFolder, yet the call goes to SuppressFolder.
Btw, you did get this code from this Manufacturing DevBlog article did you? It's worth to mention your resource(s) in your post.
Message 3 of 10
karram
Yes the suppress code from Mfg DevBloggers.
I correct the code as you mentioned its not works
Message 4 of 10
karram
Any solution for above case
Message 5 of 10
Curtis_Waguespack
Hi @karram
Something like this example should work.
I hope this helps.
Curtis
Sub Main
	RightFolder = oTopNode.BrowserFolders.Item("Right pads")
	LeftFolder = oTopNode.BrowserFolders.Item("Left pads")
		Call SuppressFolder(RightFolder, True)
		Call SuppressFolder(LeftFolder, True)
	Else
		oSuppress = (Baffle_Wall = "Left")
		Call SuppressFolder(RightFolder, Not oSuppress)
		Call SuppressFolder(LeftFolder, oSuppress)
End Sub
Sub SuppressFolder(oFolder As BrowserFolder, oSuppress As Boolean)
		Dim oObj As Object
			Call SuppressFolder(oObj, oSuppress)
			oOcc = oObj
			oOcc.Unsuppress
			If oSuppress = True Then oOcc.Suppress
			oPatt = oObj
					oOcc.Unsuppress
				Next
			Next
	Next
End Sub
Message 6 of 10
Andrii_Humeniuk
Hi @karram . In my case the code works fine, I added error information output in Logger.Info in case you have problems with the code.
Public Sub Main()
	Dim oDoc As AssemblyDocument = ThisApplication.ActiveDocument
	Dim oFolders As BrowserFoldersEnumerator = oDoc.BrowserPanes("Model").TopNode.BrowserFolders
		Call SuppressControlFolder(oFolders("Right pads"), True)
		Call SuppressControlFolder(oFolders("Left pads"), False)
	Else If Baffle_Wall = "Left" Then
		Call SuppressControlFolder(oFolders("Right pads"), False)
		Call SuppressControlFolder(oFolders("Left pads"), True)
	Else If Baffle_Wall = "NO" Then
End Sub
Private Sub SuppressControlFolder(ByVal oFolder As BrowserFolder, ByVal bSupp As Boolean)
	For Each oItem As BrowserNode In oFolder.BrowserNode.BrowserNodes
		Dim oObj As Object = oItem.NativeObject
			Call SuppressControlFolder(oObj, bSupp)
			Dim oOcc As ComponentOccurrence = oObj
			If Not oOcc.Suppressed = bSupp Then Call SuppressOcc(oOcc, bSupp)
		Else If TypeOf oObj Is OccurrencePattern Then
			Dim oPatt As OccurrencePattern = oObj
				Next
			Next
	Next
End Sub
Private Function SuppressOcc(ByVal oOcc As ComponentOccurrence, ByVal bSupp As Boolean)
	Try
		If bSupp Then : oOcc.Suppress(True)
		Else : oOcc.Unsuppress
	Catch
		If bSupp Then :	Logger.Info("Failed to Suppress - " & oOcc.Name)
		Else :	Logger.Info("Failed to Unsuppress - " & oOcc.Name)
	End Try
End Function
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
Message 7 of 10
_dscholtes_
@Curtis_Waguespack
@Curtis_Waguespack wrote:
<snip>
oOcc.Unsuppress
</snip>
Isn't this a time-consuming and unnecessary order of operations when items need to be suppressed (first unsuppress, then suppress again)? Isn't it faster / more logical to write the following instead:
Call oOcc.Suppress(oSuppress)
Message 8 of 10
Curtis_Waguespack
@_dscholtes_ wrote:
In't this a time-consuming and unnecessary order of operations when items need to be suppressed (first unsuppress, then suppress again)? Isn't it faster / more logical to write the following instead:
Hi @_dscholtes_
I think there is a little confusion about the suppress method, introduced by the original example.
The Suppress method only suppresses a component, it does not unsuppress by providing a true/false argument.
The Boolean argument (shown as True below) is an optional argument to skip the document save when suppressing a component. It is not a toggle of the suppression state
https://help.autodesk.com/view/INVNTOR/2024/ENU/?guid=ComponentOccurrence_Suppress
Call oOcc.Suppress( True)
But your point about my example being time-consuming and unnecessary is valid.
My example did indeed just unsuppress everything and then re-suppress per the value the sub is handed down.
It would be better to do as @Andrii_Humeniuk has done in his example, where the component's current suppression state is evaluated using the Suppressed property, and then only unsuppressing it if needed. See example below, for an update to my example with the change denoted in bold.
Sub Main
	Else
End Sub
		Dim oObj As Object
			oOcc = oObj
			If not oOcc.Suppressed = oSuppress Then oOcc.Unsuppress
			oPatt = oObj
					If Not oOcc.Suppressed = oSuppress Then oOcc.Unsuppress
				Next
			Next
	Next
End Sub
Message 9 of 10
HogueOne
I'm trying to make a subroutine to simply create a folder with chatgpt, but the syntax doesn't seem to work in iLogic. Would you be willing to help me fix this?
Sub Main
    ' Get the active assembly document
    ' Access the model browser pane
    ' Get the top node of the model browser
    ' Create a new folder under the top node
    Call CreateNewFolder(oTopNode, "New Folder Name")
End Sub
Sub CreateNewFolder(oParentNode As BrowserNode, folderName As String)
    ' Create a new folder under the specified parent node
    Dim newFolder As BrowserFolder
    newFolder = oParentNode.BrowserFolders.Add(folderName)
    ' Optionally, you can add items or perform additional actions within the new folder
    ' Example: Add a part file to the new folder
    ' Dim partDoc As PartDocument
    ' partDoc = ThisApplication.Documents.Add(DocumentTypeEnum.kPartDocumentObject, , True)
    ' newFolder.Add(partDoc.ComponentDefinition)
    ' You can perform additional actions here as needed
End Sub
Message 10 of 10
Curtis_Waguespack
@HogueOne
Here is an example I had on hand. It will comb through an assembly and find all purchased part ( as shown in the BOM)  and add them to a browser folder.
Sub main
	sFolder = "Purchased"
	Dim oDoc As Document
	If ThisApplication.ActiveDocument.DocumentType <> _
	DocumentTypeEnum.kAssemblyDocumentObject Then Return
	Dim oDef As ComponentDefinition
	oDef = oDoc.ComponentDefinition
	oPane = oDoc.BrowserPanes.Item("Model")
	Logger.Info("oPane.TopNode: " & oPane.TopNode.FullPath)
	Dim oTargetNode As BrowserNode
	oTargetNode = oTopNode
	'get folder if it already exists
	For Each xFolder In oTargetNode.BrowserFolders
		'Logger.Info(xFolder.name)
		If xFolder.name = sFolder
			oFolder = xFolder
	Next
	'create folder if it doesn't exist
	If oFolder Is Nothing Then oFolder = oPane.AddBrowserFolder(sFolder)
	oFolder.AllowReorder = True
	oFolder.AllowDelete = True
	Dim oNode As BrowserNode
	oNode = oPane.GetBrowserNodeFromObject(oDef.Occurrences.Item(1))
	Try
		'move folder to just below the First occurrence
		oPane.Reorder(oNode, False, oFolder.BrowserNode)
	Catch
	End Try
	Call AddtoFolder(oFolder,oDef, oPane)
	Call Reorder(oFolder, oTopNode)
End Sub
Sub AddtoFolder(oFolder As BrowserFolder,oDef As ComponentDefinition, oPane As BrowserPane)
	'stuff purchased parts into folder
	For Each oOcc In oDef.Occurrences
		If oOcc.BOMStructure = BOMStructureEnum.kPurchasedBOMStructure Then
			'add node to the folder
			'Logger.Info(oOcc.Name & " is purchased")
			oNode = oPane.GetBrowserNodeFromObject(oOcc)
			oFolder.Add(oNode)
	Next
End Sub
Sub Reorder(oFolder As BrowserFolder, oTopNode As BrowserNode)
	'[ move the folder to the top of the browser
	' Find next of EndOfFeatures
	Dim oFirstOccurrenceNode As BrowserNode
	oFirstOccurrenceNode = Nothing
	Dim lowerOfEndOfFeatures As Boolean
	lowerOfEndOfFeatures = False
	For Each oNode In oTopNode.BrowserNodes
		' Sometimes NativeObject is Nothing.
		' So you must check it is Nothing or not before accessing it.
		If Not oNode.NativeObject Is Nothing Then
			If Not lowerOfEndOfFeatures Then
				If TypeOf oNode.NativeObject Is EndOfFeatures Then
					lowerOfEndOfFeatures = True
			Else
				If Not TypeOf oNode.NativeObject Is BrowserFolder Then
					oFirstOccurrenceNode = oNode
					Exit For
	Next oNode
	' This means all of top nodes consist of the BrowserFolders.
	If oFirstOccurrenceNode Is Nothing Then
		Exit Sub
	Dim oModelPane As BrowserPane
	oModelPane = ThisApplication.ActiveDocument.BrowserPanes("AmBrowserArrangement")
	' Move the folder to before the oFirstOccurrenceNode
	Try
		oModelPane.Reorder(oFirstOccurrenceNode, True, oFolder.BrowserNode)
	Catch
	End Try
End Sub
