Specified case is not valid when drawing lines in a drawing
j_span755F8
j_span755F8
Hi there,
Im trying to draw a line in a drawing using iLogic,
I've simplified the end result in this:
' Create a new rule named "CreateLineBetweenPoints"
Sub Main()
    ' Declare variables for point coordinates
    Dim pointA(2) As Double
    Dim pointB(2) As Double
    ' Set the coordinates for point A (adjust as needed)
    pointA(0) = 5 ' X coordinate
    pointA(1) = 5 ' Y coordinate
    pointA(2) = 5 ' Z coordinate
    ' Set the coordinates for point B (adjust as needed)
    pointB(0) = 10 ' X coordinate
    pointB(1) = 20  ' Y coordinate
    pointB(2) = 10  ' Z coordinate
    ' Get the active drawing document
    Dim drawingDoc As DrawingDocument
    drawingDoc = ThisApplication.ActiveDocument
    ' Get the active sheet
    Dim sheet As Sheet
    sheet = drawingDoc.ActiveSheet
    ' Get the active view (assuming it's a base view)
    Dim baseView As DrawingView
    baseView = sheet.DrawingViews.Item(1) ' Assuming the base view is the first item
    ' Get the sketch associated with the base view
    Dim sketch As Sketch
    sketch = baseView.Sketches.Add
    ' Add the line to the sketch between point A and point B
    Dim line As SketchLine
    line = sketch.SketchLines.AddByTwoPoints(pointA, pointB)
End Sub
It gives the error on line35, case not specified,
Michael.Navara
SketchLines.AddByTwoPoints Method requires aruments of type Point2D or SketchPoint. Not array of double.
See this sample for more information
