I have a code that will insert sketch symbol that works great, and now want to put a line of code in that will check the symbol clipping box or set it before inserting it.
Dim oApp As Application: oApp = ThisApplication Dim oDoc As DrawingDocument: oDoc = oApp.ActiveDocument Dim oSheet As Sheet : oSheet = oDoc.ActiveSheet Dim oSketchedSymbol As SketchedSymbol 'assigns layer and leader Dim oLayer = oDoc.StylesManager.Layers("Auto Tag") Dim oLeader = oDoc.StylesManager.LeaderStyles("Auto Tag") Dim oDrawDoc As DrawingDocument = ThisDrawing.Document Dim oSketchSymLib As SketchedSymbolDefinitionLibrary _ = oDrawDoc.SketchedSymbolDefinitions.SketchedSymbolDefinitionLibraries.Item("Global Form Drawing Library") Dim oSSDEf As SketchedSymbolDefinition _ = oDrawDoc.SketchedSymbolDefinitions.AddFromLibrary(oSketchSymLib, "AUTO TAG", True) 'This uses a sketch symbol with the name "'View On' View Label" Dim oSymDef As SketchedSymbolDefinition : oSymDef = oDoc.SketchedSymbolDefinitions.Item(“AUTO TAG") 'This is the selected view Dim oView As DrawingView: oView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter,"Select View To Place Symbol:") 'This takes the label items of the selected view 'And adds it To an array that will link To the prompted entry Dim sPromptStrings(4) As String sPromptStrings(0) = "String 0" sPromptStrings(1) = "String 1" sPromptStrings(2) = "String 2" sPromptStrings(3) = "String 3" sPromptStrings(4) = "String 4" 'This is the position for the sketched symbol under the selected view' Dim oPosition As Point2d: oPosition = oView.Center 'oPosition.Y = oPosition.Y - (oView.Height/1.90625) 'oPosition.X = oPosition.X - (oView.Width / 500) oPosition.Y = oPosition.Y + (oView.Height/6) oPosition.X = oPosition.X + (oView.Width/5) 'This inserts the sketched symbol and fills in the prompted entry. Dim oSymbol As SketchedSymbol : oSymbol = oSheet.SketchedSymbols.Add(oSymDef, oPosition, , , sPromptStrings) oSymbol.Layer = oLayer oSymbol.LeaderStyle = oLeader
