string of code to check the symbol clipping box
nowell.colsenXK53F
nowell.colsenXK53F
I have a code that will insert sketch symbol that works great, and now want to put a line of code in that will check the symbol clipping box or set it before inserting it.
Dim oApp As Application: oApp = ThisApplication
Dim oDoc As DrawingDocument: oDoc = oApp.ActiveDocument
Dim oSheet As Sheet : oSheet = oDoc.ActiveSheet
Dim oSketchedSymbol As SketchedSymbol
'assigns layer and leader
Dim oLayer = oDoc.StylesManager.Layers("Auto Tag")
Dim oLeader = oDoc.StylesManager.LeaderStyles("Auto Tag")
Dim oDrawDoc As DrawingDocument = ThisDrawing.Document
Dim oSketchSymLib As SketchedSymbolDefinitionLibrary _
    = oDrawDoc.SketchedSymbolDefinitions.SketchedSymbolDefinitionLibraries.Item("Global Form Drawing Library")
Dim oSSDEf As SketchedSymbolDefinition _
    = oDrawDoc.SketchedSymbolDefinitions.AddFromLibrary(oSketchSymLib, "AUTO TAG", True)
'This uses a sketch symbol with the name "'View On' View Label"
Dim oSymDef As SketchedSymbolDefinition : oSymDef = oDoc.SketchedSymbolDefinitions.Item(“AUTO TAG")
'This is the selected view
Dim oView As DrawingView: oView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter,"Select View To Place Symbol:")
'This takes the label items of the selected view
'And adds it To an array that will link To the prompted entry
Dim sPromptStrings(4) As String
sPromptStrings(0) = "String 0"
sPromptStrings(1) = "String 1"
sPromptStrings(2) = "String 2"
sPromptStrings(3) = "String 3"
sPromptStrings(4) = "String 4"
'This is the position for the sketched symbol under the selected view'
Dim oPosition As Point2d: oPosition = oView.Center
'oPosition.Y = oPosition.Y - (oView.Height/1.90625)
'oPosition.X = oPosition.X - (oView.Width / 500)
oPosition.Y = oPosition.Y + (oView.Height/6)
oPosition.X = oPosition.X + (oView.Width/5)
'This inserts the sketched symbol and fills in the prompted entry.
Dim oSymbol As SketchedSymbol : oSymbol = oSheet.SketchedSymbols.Add(oSymDef, oPosition, , , sPromptStrings)
oSymbol.Layer = oLayer
oSymbol.LeaderStyle = oLeader
Accepted solutions (3)
A.Acheson
This should do it. Source is the API help and search  sketched symbol object
Syntax
SketchedSymbol.SymbolClipping() As Boolean
Regards
Alan
nowell.colsenXK53F
I get this error
"Error on Line 10 : Reference to a non-shared member requires an object reference."
A.Acheson
The error message suggest you have an object not correctly referenced. Did you by chance place the symbol clipping snippet directly into the code as is without referencing the object?
oSymbol.SymbolClipping = True
Regards
Alan
