Stress Analysis via Visual Basic Application
dominikkedzia
Observer Observer
Message 1 of 1
dominikkedzia
Observer
Observer
I'm working on some project that requires me to prepare automated Stress Analysis to run on previously generated model.
Model generation is already done.
Now I need to execute stress analysis, which is normally fired from Envirments/Stress Analysis and then Analysis/Create Study.
Firstly I need Static Analysis and then Modal Analysis.
I'd like to know how to prepare Material, Contraints, Loads and Contacts.
For now I was managed to open Create Study window and that is it 😞
Dim oDoc As Document = ThisApplication.ActiveDocument
'if stress simulation is activated
Dim UIManager As UserInterfaceManager = ThisApplication.UserInterfaceManager
If UIManager.ActiveEnvironment.InternalName <> "FEA Environment Internal Name" Then
    'if it is not activated
    Dim environmentMgr As EnvironmentManager = oDoc.EnvironmentManager
    Dim dsEnv As Environment = UIManager.Environments.Item("FEA Environment Internal Name")
    Call environmentMgr.SetCurrentEnvironment(dsEnv)
End If
'get Create Study Command
Dim oCol As ControlDefinition = ThisApplication.CommandManager.ControlDefinitions("FeaCreateSimCmd")
oCol.Execute()
^ it works.
At this point in couple of threads on forum I've seen suggestion to add this Control Definitions:
Dim oCol2 As ControlDefinition = ThisApplication.CommandManager.ControlDefinitions("AppContextual_OKCmd")
oCol2.Execute()
But it fails to do anythig and I've seen another suggestion to execute {SPACE} key between this two code blocks, so I had try with these two:
System.Windows.Forms.SendKeys.Send(" ")
'and
My.Computer.Keyboard.SendKeys(" ")
Both of them failes to execute - it keeps throwing an System.InvalidOperationException with message that says It is unable to run SendKeys in application, because it does not handle communicates/messages of Windows and I should change the application to somehow handle this or use SendKeys.SendWait, so i did it and change {SPACE} approach to {ENTER}:
System.Windows.Forms.SendKeys.SendWait("{ENTER}")
After script execution is over, the Create New Study window is still open with title "Analysis 2", but I see that Static Analysis is created (with ID = 1) in Model Browser on the left side of the Inventor window. So it doesn't works perfectly and the most important - I don't know what's next.
I've deleted:
oCol2.Execute()
It works the same. Magic.
I still don't know how to change default Static Analysis to Modal Analysis, moving forword with Modal Analysis - I don't know how to change default values in inputs.
Maybe more important - I don't know from where strings FeaCreateSimCmd and AppContextual_OKCmd comes from - I found nothing in inventor documentation. The source of that I found here: https://adndevblog.typepad.com/manufacturing/2013/08/run-stress-simulation-by-code.html
If you have any of these answers or any suggestion - I would very appreciate you to respond, even if you see this thread long time after publishing - maybe it will help someone else in the future.
At the end, I'd like to sum up what I have now and what it results with.
The code:
End If
oCol.Execute()
And the result:
Replies (0)
