Stress Analysis: Parametric Loads
When performing a parametric study in the stress analysis environment in Autodesk Inventor, I tried to use a parameter to define one of the loads in the study; it worked. However, it wasn't possible to use the same parameter in the parametric table and perform several analyses varying the load over the bodies. So, my question is whether there is a way to do this kind of analyses or not. If not, then I suggest to include this option into your further updates, for a such analysis is very useful to observe how the same geometric configuration of your model behaves when the load changes, and all this without needing to create several studies.
tomasz.piasecki
Community Visitor
Community Visitor
I have the same issue. I can't figure out how to set up a parametric load simulation. It wouls be very useful.
harvey_craig2RCUH
I've come across this 7 years later, did you find a way to do this?
