Accept 'Do you want to use resolved file' message
CadUser46
CadUser46
Is there a way to default this response to Yes and/or hide the message when batch processing files?
Inventor 2010 Certified Professional
Currently using 2023 Pro
HermJan.Otterman
did you try to use the
thisapplication.silentoperation = true option?
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
frederic.vandenplas
Hi @CadUser46 you can try this, there are many options where you can decide what to do in case of.
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
CadUser46
Herjan.  I have tried your suggestions but it did not work.
Frederik, not too sure what your were pointing me to.
I have a work around for this which is to use another program called PushButtons.  It listens for the HWND of the dialogue and presses it whenever detected.
