Step through part dimension visibility
rogmitch
rogmitch
I have been trying to sequentially show (and then hide) the dimensions for each feature (together with  its related sketch dimensions)  in a part browser tree.
 I can set the visibility for any one of the sketches with e.g.
oSketches.Item(1).Visible = True
oSketches.Item(1).DimensionsVisible = True 'Show sketch dimension
and show the visibilty of the feature dims with e.g.
Set oFeature = odef.Features.Item(1)
oFeature.FeatureDimensions.Show  'Show feature dimension
but I cannot work out how to test which feature a particular sketch is dependent upon. Until I do this the visibiliy
of the feature and sketch dimensions cannot be synchronised.
 I expected something like
If odef.Features.Item(1) = oSketch.Parent might work or maybe the  Isownedby function but so far I have had no luck with anything I have tried.
If anyone can help I would much appreciate it.
Roger Mitchell
rogmitch
Update- I worked out one way to check if a feature has a dependent sketch. Just in case anybody is interested the following returns the 1st sketch item number under a feature
Function CheckFeaturehasSketch(intFeatureNum As Long) As Long
Dim odef As PartComponentDefinition
Set odef = oPartDoc.ComponentDefinition
Set oSketches = odef.Sketches
Dim oFeature As PartFeature
Dim oSketch As PlanarSketch
Dim intcount As Long
For Each oSketch In oSketches
intcount = intcount + 1
On Error Resume Next
If oSketch Is odef.Features.Item(intFeatureNum).Profile.Parent Then
If Err <> 0 Then Exit Function 'Feature does not have sketch
CheckFeaturehasSketch = intcount
Exit Function
Next
End Function
If anyone knows a tidier way to do this please post.
philippe.leefsma
Some Faetures are sketch-based and some other aren't, eg. fillets, chamfers, ...
For sketch based features, Feature.Profile.Parent "is" the sketch the feature is based upon, so i don't understand why you would need to go the other way around and iterate through all sketches to compare it... Going from the sketch you can try to use "PlanarSketch.Dependents" property to find the feature.
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
