DrawingView.MoveTo Method
jdkriek
Advisor Advisor
jdkriek
What is the proper way to use this method? Not having any luck.
Also tried using oDoc.Sheets.Item(2) for Target Sheet.
Public Sub MoveViews()
    Dim oApp As Application
    Set oApp = ThisApplication
    Dim oDoc As DrawingDocument
    Set oDoc = oApp.ActiveDocument
    Dim oSheet As Sheet
    Set oSheet = oDoc.ActiveSheet
    ' Check to make sure a view was selected.
    If Not TypeOf oDoc.SelectSet.Item(1) Is DrawingView Then
        MsgBox "A drawing view must be selected."
        Exit Sub
    Dim oDrawingView As DrawingView
    Set oDrawingView = oDoc.SelectSet.Item(1)
    ' Test to see if we have the view
    oDrawingView.ShowLabel = True
    ' Move view to target sheet
    oDrawingView.MoveTo ("Sheet:2")
End Sub
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
YuhanZhang
Can you double check that the active sheet is Sheet:2 or not? You could not move a drawing view to the same sheet it is located in.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
jdkriek
Rocky,
Yes Sheet:1 is active and I cannot move it to Sheet:2
Also the view is stand-alone, not a section or view with parent.
Tested in 2011, 2012, and 2013
Jonathan D. Kriek
YuhanZhang
Seems there is a code error, please use below updated code:
    Dim oSheet As Sheet
        Exit Sub
    oDrawingView.MoveTo oDoc.Sheets("Sheet:2")
End Sub
Rocky Zhang
Inventor API PD
Autodesk, Inc.
