StatusBarText
StatusBarText
gilsdorf_e
StatusBarText
gilsdorf_e
I'm in need to track the idle status of Inventor from an external application. My idea was to use the StatusBarText (at least I imagined that the "Ready" text in the bottom bar is the StatusBarText). I have reused that text already in Inventor 2014 from AutoIt, yet I already noticed that this is not possible anymore in Inventor 2016.
Even through Inventor API, the Application.StatusBarText is always an empty string. Was this function removed and are there alternative options to track if Inventor has finished all tasks and is idleing?
Best regards
Erik Gilsdorf
Owner2229
TLDR: There's a function on the Inventor.Application object you can use to check if it's idle.
You can then create a function to hold your threat until Inventor loads up, something like:
Public Sub Inventor_WaitForReady(iApp As Inventor.Application)
	If iApp.Ready Then Exit Sub
	While True
		Threading.Thread.Sleep(100)
		If iApp.Ready Then Exit While
	End While
End Sub
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
gilsdorf_e
Thank you, but I already checked the Inventor.Application.Ready property. This just means that Inventor has started and loaded all addins. So this is always true after Inventor has started. I cannot judge by this property if Inventor is loading an assembly or calculating something.
b_sharanraj
Please try this one 🙂
MsgBox (ThisApplication.CommandManager.CreateInteractionEvents.StatusBarText)
Regards
B.Sharan Raj
gilsdorf_e
Sorry for the late answer. Unfortunately the value seems to be always "Ready", even if Inventor is updating a large assembly model (the status bar in the UI does not display "Ready".
class Program
        static void Main(string[] args)
            Inventor.Application invApp;
            invApp = (Inventor.Application)System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application");
                String test = invApp.CommandManager.CreateInteractionEvents().StatusBarText;
           // invApp.Documents.CloseAll();
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @gilsdorf_e,
Unfortunately, StatusBarText is not giving status of Inventor. But, there are many events to capture the status of Inventor.
Try "EventWatcher.exe" which is explained in detail in below blog link.
http://modthemachine.typepad.com/my_weblog/2009/03/running-commands-using-the-api.html
Please feel free to contact if there is any queries,
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
