Starter to Autodesk Programming
I am just going to start a project for autodesk programming.
My question is:
My Computer does not have Autodesk Valut or  Inventor installed, but
I just installed the usertools.msi and developertools.msi.
I need to use .Net for the programming.
Is it possible to create and user Inventor application object on this system (which does not having complete Autodesk installed.)
I tried it but I am getting error "Cannot create activex component" when I try to create object for Inventor.
Please reply.
Vinaya
If you are going to program Inventor I would have thought it would be a pre-requsite to have a working installation of Inventor on your computer.
How else can you check your code?
