Square Meter based on material and thickness
donaldleigh
donaldleigh
Evening all
I have found and edited the attached rule (Thanks to Cadline) .  This rule will, from an assembly, enter the m2 of each sheet metal part into a custom iProperty, What I would like to do (and not sure how to) is add these up based on both material and thickness, Issue I have is the material could be any number of materials and same with the thicknesses.
Cheers
Donald
gcoombridge
I think if you had a set list of materials and thicknesses this would be much easier... I'd be interested to see how this could be done though. Maybe some kind of 2 dimensional array sorted by several columns.
Use iLogic Copy? Please consider voting for this long overdue idea (not mine):https://forums.autodesk.com/t5/inventor-ideas/string-replace-for-ilogic-design-copy/idi-p/3821399
