Spiral stair single string
Hello.
I need help creating a spiralt stair with single string in the middle of the stairs.
please see link: https://www.youtube.com/watch?v=jQv73SlxoN4
Owner2229
Hey, do you want to do so programmatically or by hand? Anyway, in both cases, you'll follow the same steps:
Each step looks to be straight, so there's nothing easier than creating a spline, adding the first step to the bottom of it and creating a pattern on the spline.
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
