Specifying a midplane option in a pattern
keithjk
keithjk
I am creating a rectangular pattern along the x axis and I want it to be bidirectional (or the midplane option in the UI).  The following snippet works fine but how do I use the mid plane option?
Dim oPattern As OccurrencePattern = oAssyDef.OccurrencePatterns.AddRectangularPattern(objCol, XAxis, True, xExtents, Convert.ToInt16(Val(txtPatternNo.Text)))
Owner2229
Hey, try adding this (after the pattern creation):
oPattern.Definition.XDirectionMidPlanePattern = True
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
keithjk
Thanks for the reply but that doesn't work. I get a "definition on type RectangularOccurrencePattern not found error".
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi Keith,
Unfortunately, current Inventor 2018 API does not support to set midplane for RectangularOccurancePattern.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
JamieVJohnson2
Well what about the Inventor 2020 API?  Don't you think it should be supported by now?
Jamie Johnson : Owner / Sisu Lissom, LLC https://sisulissom.com/
chandra.shekar.g
Autodesk Support
Autodesk Support
@JamieVJohnson2,
Still Inventor API is not supported to mention midplane for RectangularOccurrencePattern. Please log a wish list at idea station using below link.
https://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
