special characters
special characters
GosponZ
special characters
GosponZ
I'm using this rule to fill browser in idw and is working good, but now in another company we using special characters in material description. Would be possible to remove special characters.
oDoc = ThisDoc.Document
oSheets = oDoc.Sheets
For Each oSheet In oSheets
oSheet.activate
oView = oSheet.DrawingViews.Item(1)
modelName = oView.ReferencedDocumentDescriptor.ReferencedDocument
If modelName.DocumentType = DocumentTypeEnum.kPartDocumentObject 'Only set property based name for part views
oProp = modelName.PropertySets.Item("Design Tracking Properties")
ocProp = modelName.PropertySets.Item("Inventor User Defined Properties") 'Custom property set
ActiveSheet.Sheet.Name = oProp.Item("Material").Value & " " & " " & oProp.Item("Part Number").Value & " " & oProp.Item("Description").Value
End If
Next
oSheets(1).activate
A.Acheson
Here is a function to remove special characters, function source from stack overflow
Sub Main
	Dim Name As String = "Hello?!#"
	'Replacement string for name having ilegal Characters.
	Dim replace_with As String = ""
	'Function to remove ilegal characters from Style Name before saving file
	Dim NewName As String = clean_filename(Name, replace_with)
	MessageBox.Show(NewName, "Title")
End Sub
Function clean_filename(Name As String, replace_with As String)
    Dim inv_chars As String
    Dim cpos As Long
    invchars = "'!""#¤%&/()=?`^*>;:@£${[]}|~\,.'¨´+-"
    For cpos = 1 To Len(invchars)
        Name = Replace(Name, Mid(invchars, cpos, 1), replace_with)
    Next
    clean_filename = Name
End Function
Regards
Alan
GosponZ
I'm not sure this one will work for me. I have that rule.
The thing is when i run rule i post above it supposed to write in browser tree material, but since material has in description / and " it will not run. I need description in browser to show material w/o quotes and back slash. If that can happen would be great.
Thank you for response
A.Acheson
See if this will work. If it doesn't can you post the errors your seeing?
Sub Main
		oSheet.activate
		Dim OldMaterialName As String = oProp.Item("Material").Value
		'Function to remove ilegal characters from Style Name before saving file.
		Dim MaterialName As String = clean_filename(OldMaterialName, replace_with)
		ActiveSheet.Sheet.Name = MaterialName & " " & " " & oProp.Item("Part Number").Value & " " & oProp.Item("Description").Value
		End If
	Next
	oSheets(1).activate
End Sub
    Dim cpos As Long
    Next
End Function
Regards
Alan
GosponZ
No error, this is what i need. Thank you so much
