Sorting Parameters smallest to largest
I am trying to sort Parameters (Width, Height, Thickness) from smallest to largest and then put that format into an iProperty.  No matter what combination of values I try it always returns the WidthxHeightxThickness combination.
Is iLogic unable to handle these types of expressions or am I missing something very obvious?
Here is my code:
If Width <= Height <= Thickness = True Then
	stock = "=<Width>x<Height>x<Thickness>"
ElseIf Width > Height <= Thickness = True Then
	If Thickness > Width = True Then
		stock = "=<Height>x<Width>x<Thickness>"
	Else
		stock = "=<Height>x<Thickness>x<Width>"
	End If
ElseIf Width < Height > Thickness = True Then
	If Width < Thickness = True Then
		stock = "=<Width>x<Thickness>x<Height>"
	Else
		stock = "=<Thickness>x<Width>x<Height>"
	End If
Else
	stock = "=<Thickness>x<Height>x<Width>"
End If
iProperties.Value(doc, "Project", "Description") = stock
MessageBox.Show(stock, "Order")
ckeveryga
Try this.
Dim dblLength, dblWidth, dblThickness As Double
dblHeight = Convert.ToDouble(Parameter.Param("Height").Value)
dblWidth = Convert.ToDouble(Parameter.Param("Width").Value)
dblThickness = Convert.ToDouble(Parameter.Param("Thickness").Value)
Dim dblArray() As Double = {dblHeight, dblWidth, dblThickness }
Dim strArray() As String = {"Height","Width","Thickness"}
Array.Sort(dblArray, strArray)
Array.Reverse(strArray)
iProperties.Value("Project", "Description") = "=<" & strArray(0) & ">x<" & strArray(1) & ">x<" & strArray(2) & ">"
This works! Only thing is the Array.Sort(dblArray, strArray) already puts the order in smallest to largest so the Array.Reverse(strArray) undoes the work.
Thanks a ton for your help!
Regarding my code is iLogic/VBA unable to handle expressions such as W<=H<=T?
ckeveryga
Oops, thought you needed largest to smallest.
Correct, you can only do one boolean expression at a time (I'm fairly certain at least). So instead of W<=H<=T, you would put:
If W <= H And H <= T Then
