Sort part list by part number
firelinsgs
firelinsgs
Hi, i trying to Sort part list by Part number. But this code doesnt work for me. Only renumbering works..
Any idea why?
SyntaxEditor Code Snippet
On Error Resume Next
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
Dim oPartsList As PartsList
oPartsList = oDrawDoc.ActiveSheet.PartsLists.Item(1)
If Not oPartsList Is Nothing Then
Call oPartsList.Sort("PART NUMBER")
oPartsList.Renumber
oPartsList.SaveItemOverridesToBOM
rhasell
Works just fine, the sort just isn't that good, You may find that you get random results between drawings. It's still sorted, just not what you expect.
I find that you may need to add additional items to the parts list to improve the sorting. You can sort up to 3 columns.
TIP:
When you create the Parts list, change the column width to '1' this will effectively hide the column from view.
EG:
oPartsList.Sort("COST CENTER",1,"TYPE", 1, "STOCK NUMBER", 1)
"Cost Center" as Broad strokes sorting
"Type" is a custom field for finer sorting.
etc
In this example all the columns beyond "Length" are hidden from view.
Reg
2026.1
firelinsgs
Thanks for your reply. But what i want is just simple short the part list by "Part Number" and renumber item.
Check attachment files.
I use INV. 2018
rhasell
Hi
The Sample data was perfect.
Found the problem.
The "PART NUMBER" is case sensitive, The code and the Parts list don't match.
Revised code:
Call oPartsList.Sort("Part number",1)
oPartsList.Renumber
Reg
2026.1
firelinsgs
Thanks, 🙂 So little difference and it does work.
rhasell
Pleasure
Glad I could help.
Reg
2026.1
