Sort names of PositionalRepresentations and LevelOfDetailRepresentations
GeorgK
Advisor Advisor
Message 1 of 8
GeorgK
Hello together,
is there any way to sort the names of the PositionalRepresentations and LevelOfDetailRepresentations? Manually I copy all the PositionalRepresentations and LevelOfDetailRepresentations in the right order and delete the old ones.
Private Sub Button28_Click(sender As Object, e As EventArgs) Handles Button28.Click
        Dim m_inventorApp As Inventor.Application = Nothing
        ' Try to get an active instance of Inventor
        Try
            m_inventorApp = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application")
        Catch ex As Exception
            MsgBox(ex.Message)
        End Try
        Dim oAsmCompDef As AssemblyComponentDefinition
        oAsmCompDef = m_inventorApp.ActiveDocument.ComponentDefinition
        'define pos rep
        Dim oPosRep As PositionalRepresentation
        Dim MyArrayList As New ArrayList
        'record the active view rep name
        Dim sActivePosRep As String
        sActivePosRep = oAsmCompDef.RepresentationsManager.ActivePositionalRepresentation.Name
        For Each oPosRep In oAsmCompDef.RepresentationsManager.PositionalRepresentations
            MyArrayList.Add(oPosRep.Name)
        Next
        Dim MyArrayList1 As New ArrayList
        Dim oRepManager As RepresentationsManager
        oRepManager = oAsmCompDef.RepresentationsManager
        For Each oLODRep In oRepManager.LevelOfDetailRepresentations
            MyArrayList1.Add(oLODRep.Name)
        Next
        MyArrayList.Remove("Hauptansicht")
        MyArrayList1.Remove("Hauptansicht")
        MyArrayList1.Remove("Alle Komponenten unterdrückt")
        MyArrayList1.Remove("Alle Bauteile unterdrückt")
        MyArrayList1.Remove("Gesamtes Inhaltscenter unterdrückt")
        ' Sorts the values of the ArrayList.
        MyArrayList.Sort()
        ' Displays the values of the ArrayList.
        Console.WriteLine("After sorting:")
        PrintValues(MyArrayList)
        MyArrayList1.Sort()
        PrintValues(MyArrayList1)
    End Sub
    Public Shared Sub PrintValues(myList As IEnumerable)
        Dim obj As [Object]
        For Each obj In myList
            Console.WriteLine("   {0}", obj)
        Next obj
        Console.WriteLine()
    End Sub 'PrintValues
Thank you
Georg
Replies (7)
Message 2 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @GeorgK,
Unfortunately, Inventor API does not support sorting of PositionalRepresentations and LevelOfDetailRepresentations.
Default PositionalRepresentations and LevelOfDetailRepresentations can not be sorted. Due to fact that it can not deleted.
Other than defaults, Representations can be stored in ArrayList and delete it. Then, after sorting names in ArrayList, Representations can be added.
Please feel free to contact if there is any doubt.
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 3 of 8
GeorgK
Hello @chandra.shekar.g,
I know the limitations. But I can change those which I created by my own.
Is there a way to save the existing PositionalRepresentations and LevelOfDetailRepresentations, delete them and recreate them in a new order?
Georg
Message 4 of 8
GeorgK
It's much easier:
Dim oDoc As Inventor.Document = m_inventorApp.ActiveDocument
Dim oCD As ComponentDefinition = oDoc.ComponentDefinition
Dim oPR As PositionalRepresentation = oCD.RepresentationsManager.PositionalRepresentations("Position1")
oPR.Copy("01_Position1")
Message 5 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @GeorgK,
Try the following VB.Net code to sort PositionalRepresentations and LevelOfDetailRepresentaions.
Dim mApp As Inventor.Application = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application")
oAsmCompDef = mApp.ActiveDocument.ComponentDefinition
oRepManager = oAsmCompDef.RepresentationsManager Call oRepManager.PositionalRepresentations.Item(1).Activate() If oRepManager.PositionalRepresentations.Count > 1 Then Dim arrPos As New ArrayList For i As Integer = oRepManager.PositionalRepresentations.Count To 2 Step -1 Dim oPosRep As PositionalRepresentation oPosRep = oRepManager.PositionalRepresentations.Item(i) arrPos.Add(oPosRep.Name) oPosRep.Delete() Next arrPos.Sort() For Each str As String In arrPos oRepManager.PositionalRepresentations.Add(str) Next End If Call oRepManager.PositionalRepresentations.Item(1).Activate() Call oRepManager.LevelOfDetailRepresentations.Item(1).Activate() If oRepManager.LevelOfDetailRepresentations.Count > 4 Then Dim arrLOD As New ArrayList
For i As Integer = oRepManager.LevelOfDetailRepresentations.Count To 5 Step -1 Dim oLOD As LevelOfDetailRepresentation oLOD = oRepManager.LevelOfDetailRepresentations.Item(i) arrLOD.Add(oLOD.Name) oLOD.Delete() Next ' Sorts the values of the ArrayList. arrLOD.Sort() For Each str As String In arrLOD oRepManager.LevelOfDetailRepresentations.Add(str) Next End If Call oRepManager.LevelOfDetailRepresentations.Item(1).Activate()
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 6 of 8
GeorgK
thats great for a new design. But I would like to change the order for an existing design. All values are deleted with your code. Therefore I thougt of copy all PositionalRepresentations and LevelOfDetailRepresentations in the right order and delete afterwards the old list.
Old:
05_Position
03_Position
02_Position
01_Position
04_Position
New with copy:
05_Position
03_Position
02_Position
01_Position
04_Position
01_Position1
02_Position1
03_Position1
04_Position1
05_Position1
Dim oPR As PositionalRepresentation = oCD.RepresentationsManager.PositionalRepresentations("02_Position")
oPR.Delete
Delete old order:
01_Position1
02_Position1
03_Position1
04_Position1
05_Position1
Rename:
01_Position
02_Position
03_Position
04_Position
05_Position
I hope it is more clear what I try to get.
Georg
Message 7 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @GeorgK,
Try the following VB.Net code.
                arrPos.Add(oRepManager.PositionalRepresentations.Item(i).Name)
            Next
            arrPos.Sort()
            Dim j As Integer = 0
                oRepManager.PositionalRepresentations.Item(i).Copy(arrPos.Item(j) & "1")
                j = j + 1
            Next
                Dim str As String
                str = oRepManager.PositionalRepresentations.Item(i).Name
                If str.Substring(str.Length - 1) <> "1" Then
                    Call oRepManager.PositionalRepresentations.Item(i).Delete()
            Next
                Dim str As String
                If str.Substring(str.Length - 1) = "1" Then
                    oRepManager.PositionalRepresentations.Item(i).Name = str.Remove(str.Length - 1)
            Next
                arrLOD.Add(oRepManager.LevelOfDetailRepresentations.Item(i).Name)
            Next
            arrLOD.Sort()
                oRepManager.LevelOfDetailRepresentations.Item(i).Copy(arrLOD.Item(j) & "1")
                j = j + 1
            Next
                Dim str As String
                str = oRepManager.LevelOfDetailRepresentations.Item(i).Name
                    Call oRepManager.LevelOfDetailRepresentations.Item(i).Delete()
            Next
                Dim str As String
                    oRepManager.LevelOfDetailRepresentations.Item(i).Name = str.Remove(str.Length - 1)
            Next
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 8 of 8
GeorgK
@chandra.shekar.g
Thats a great tool. Thank you very much. This should be in Inventor 2018!
Georg
