Message 1 of 1
Sort Interference Results using iLogic
11:52 AM
This is my first post in the forum, and I'm certainly not a programmer so please bear with me.
I have an iLogic rule that I've created that will go through the interference results and count and display them individually, but they just appear in whatever order Inventor decides. I would like to sort interference results by volume and then display them in order of largest volumes first. I'm only concerned with keeping the OccurrenceOne , OccurrenceTwo , and Volume properties together. I've attempted to use an ArrayList to no avail.
The code I have is posted below.
Any help would be appreciated.
Sub Main 'check this file is an assembly Dim doc As Document = ThisApplication.ActiveDocument If doc.DocumentType = kPartDocumentObject Then MessageBox.Show("This rule can only be run in an assembly file!", "ERROR") Return End If Dim oAsmDoc As AssemblyDocument oAsmDoc = ThisApplication.ActiveDocument Dim oAsmCompDef As AssemblyComponentDefinition oAsmCompDef = oAsmDoc.ComponentDefinition ' Add each occurrence in the assembly to the object collection. Dim oCheckSet As ObjectCollection oCheckSet= ThisApplication.TransientObjects.CreateObjectCollection Dim oOcc As ComponentOccurrence For Each oOcc In oAsmCompDef.Occurrences oCheckSet.Add (oOcc) Next ' Call the AnalyzeInterference method, passing in a single' collection. This will cause it to compare everything against' everything else. Dim oResults As InterferenceResults oResults = oAsmCompDef.AnalyzeInterference(oCheckSet) Dim oResult As InterferenceResult ''''''''''''''''''''''''''''' 'FILTERING GOES HERE ''''''''''''''''''''''''''''' 'Count and display number of interferences. Dim Result_Count As Integer Result_Count = 0 For Each oResult In oResults Result_Count = Result_Count + 1 Next ' Display the results of the interference. MessageBox.Show(Result_Count & " Interferences found ","iLogic") 'Iterate through And display Each interference individually Dim answer As String Dim oIntBody As SurfaceBody Dim oBody As SurfaceBody Dim oSurfaceGraphics As SurfaceGraphics Dim oClientGraphics As ClientGraphics Dim oSurfacesNode As GraphicsNode iCount = 0 Dim x As Integer x=1 For Each oResult In oResults iCount = iCount + 1 oResult.OccurrenceOne.SetRenderStyle(100609,oAsmDoc.RenderStyles.Item("Yellow")) oResult.OccurrenceTwo.SetRenderStyle(100609,oAsmDoc.RenderStyles.Item("Cyan")) ''''''''''''''''''''''''''''' 'Create temporary surface for displaying interfering body ' Create the ClientGraphics object. oClientGraphics = oAsmCompDef.ClientGraphicsCollection.Add("Sample3DGraphicsID") ' Create a new graphics node within the client graphics objects oSurfacesNode = oClientGraphics.AddNode(1) oIntBody = oResults.Item(iCount).InterferenceBody oBody = oIntBody ' Create client graphics based on the transient body oSurfaceGraphics = oSurfacesNode.AddSurfaceGraphics(oBody) oSurfacesNode.RenderStyle = oAsmDoc.RenderStyles.Item("Red") oSurfaceGraphics.BurnThrough=True ' Update the view to see the resulting curves ThisApplication.ActiveView.Update ''''''''''''''''''''''''''''' 'Display Interference Result answer = MessageBox.Show(" " & FullOccurrenceName(oResult.OccurrenceOne) & " (Colored Yellow)" _ & vbLf & "interferes with " _ & vbLf & " " & FullOccurrenceName(oResult.OccurrenceTwo) & " (Colored Cyan)" _ & vbLf & "" _ & vbLf & " Interference (Colored Red)" _ & vbLf & "Volume: " & Round(oResult.Volume/16.3871,5) & " in^3", _ " Interference "& iCount & " of "& Result_Count,MessageBoxButtons.OKCancel) oResult.OccurrenceOne.AppearanceSourceType = 100612 'kPartAppearance oResult.OccurrenceTwo.AppearanceSourceType = 100612 'kPartAppearance oClientGraphics.Delete 'When user clicks cancel If answer= 2 Then 'Color Return to Normal For Each oOcc In oAsmDoc.ComponentDefinition.Occurrences ' Set each occurrence to use the part defined color. oOcc.SetRenderStyle(StyleSourceTypeEnum.kPartRenderStyle) Next Return End If Next 'Color Return to Normal For Each oOcc In oAsmDoc.ComponentDefinition.Occurrences ' Set each occurrence to use the part defined color. oOcc.SetRenderStyle(StyleSourceTypeEnum.kPartRenderStyle) Next End Sub ' Used to display the full path of an occurrence. This is the path of the' occurrence within the assembly structure. Private Function FullOccurrenceName(Occ As ComponentOccurrence) As String Dim i As Integer For i = 1 To Occ.OccurrencePath.Count If i = 1 Then FullOccurrenceName = Occ.OccurrencePath.Item(i).Name Else FullOccurrenceName = FullOccurrenceName & "\" & Occ.OccurrencePath.Item(i).Name End If Next End Function
