Get face from selected edge
NachoShaw
Advisor Advisor
NachoShaw
Hi
Is there a way to select the 2 faces comnected to a selected edge in a drawing?
Cheers
Nacho
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
bshbsh
If I understand correctly, you want something like this?
Public Sub SelectFaces()
    If ThisApplication.ActiveDocument Is Nothing Then
        Exit Sub
    Else
        Dim InvDoc As Document
        Set InvDoc = ThisApplication.ActiveDocument
    If InvDoc.DocumentType <> kDrawingDocumentObject Then
        MsgBox ("Open a drawing document first!")
        Exit Sub
    If InvDoc.SelectSet.Count = 0 Then
        MsgBox ("Select an edge first")
        Exit Sub
    If InvDoc.SelectSet.Item(1).Type = kDrawingCurveSegmentObject Then
        Dim oEdge As Variant
        Set oEdge = InvDoc.SelectSet.Item(1)
        Dim oModel As Document
        Set oModel = ThisApplication.Documents.Open(oEdge.Parent.Parent.ReferencedDocumentDescriptor.FullDocumentName)
        oModel.Activate
        oModel.SelectSet.Clear
        oModel.SelectSet.Select (oEdge.Parent.ModelGeometry.Faces.Item(1))
        oModel.SelectSet.Select (oEdge.Parent.ModelGeometry.Faces.Item(2))
    Else
        MsgBox ("Selected item is not an edge!")
End Sub
This needs more error filtering though. It will fail on certain selected "edges" that do not have associated faces, such as thread lines, tangential lines, etc.
NachoShaw
Hi
Thanks for the reply. I actually had put the incorrect information in my post. I dont need to do it in a drawing, i need to do it in an assembly.
I need to select an edge in an assembly and select both faces directly attached to the edge
sorry for the misunderstanding 🙂
Nacho
Nacho
NachoShaw
Hi
im actually tyinking that i may need to go a bit deeper. the faces i need to have selected from the edge will be on a part in the assembly but i dont want to open the part independently so i guess it will using the part definition or proxy?
Cheers
Nacho
Nacho
bshbsh
        Exit Sub
    Else
    If InvDoc.DocumentType <> kAssemblyDocumentObject Then
        MsgBox ("Open an assembly document first!")
        Exit Sub
        Exit Sub
    If InvDoc.SelectSet.Item(1).Type = kEdgeProxyObject Then
        Dim oEdge As Object
        InvDoc.SelectSet.Clear
        InvDoc.SelectSet.Select (oEdge.Faces.Item(1))
        InvDoc.SelectSet.Select (oEdge.Faces.Item(2))
    Else
End Sub
NachoShaw
Hi
Thanks for that. works ok. i added a user selection instead of hsving an edge preselected 🙂
to slightly further this, is there a method of selecting the midpoint of the selected edge too? This would be after the faces have been selected
cheers
nacho
Nacho
