Snapping line to a center of gravity
Nauris47
Nauris47
Hello, im trying to build a geo dome out of icosahedron, and i faced a problem while doing that.
The problem is that i need to draw a 3D line from a center point of icosahedron to the one of the faces edge. Ive tried to add Center of Gravity and draw a line but it doesn't snap to it, is there any other way i could achieve this ?
Thanks in advance !
creggo
Here's an ilogic rule to create a workpoint at the CoG. Works well for us!
I believe this was the original source: https://forums.autodesk.com/t5/inventor-forum/center-of-gravity-as-work-point/td-p/2451558
Dim oDoc As Document = ThisDoc.Document
If oDoc.DocumentType = Inventor.DocumentTypeEnum.kDrawingDocumentObject Then
i = MessageBox.Show("The CoG rule is for use in part (ipt) or assembly files (iam) only.", "Wrong Document Type", MessageBoxButtons.OK, MessageBoxIcon.Warning, MessageBoxDefaultButton.Button1)
ElseIf oDoc.DocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject Or Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then
    ' Get the Center of Mass.
    Dim oCenterOfMass As Point
    oCenterOfMass = oDoc.ComponentDefinition.MassProperties.CenterOfMass
    ' Check to see if a work point for center of mass already exists.
    ' This uses the name of the work feature to identify it.
    On Error Resume Next
    Dim oWorkPoint As WorkPoint
    oWorkPoint = oDoc.ComponentDefinition.WorkPoints.Item("Center Of Mass")
    If Err.Number = 0 Then
        Dim oFixedDef As AssemblyWorkPointDef
        oFixedDef = oWorkPoint.Definition
        oFixedDef.Point = oCenterOfMass
        oDoc.Update
    Else
        ' Create a new workpoint at the location of the center of mass.
        oWorkPoint = oDoc.ComponentDefinition.WorkPoints.AddFixed(oCenterOfMass)
        ' Rename the work point.
        oWorkPoint.Name = "Center Of Mass"
 Cheers
Nauris47
Thanks for the possible solution, but i get a error on line 10, any idea whats causing it ?
creggo
Ahh, looking at the screenshots again, is your part made of surfaces? I think the rule will only work if there's solid bodies.
Nauris47
Thanks ! i've made it to solid ant it works perfectly now. Thank you once again, have a great day.
