Accessing the lines in the sketch within the ipt entity
hayattangercekler2
Message 1 of 12
hayattangercekler2
Hello everyone, happy day. I have an ipt file and in it I have a simple drawing that comes ready on the sketch. I want to access my lines in this drawing. I found a code block. It works with ilogic but not on api. The error I get is not being able to access the ComponentDefinition property of the document. When I do this on the iam file, I can set it as AssemblyDocument and access it. When I try this after opening the ipt entity, it fails. How do I fix this problem and I can access my lines.
My have code the Ilogic
Sub Main()
	sPointOneX = 15
	sPointOneY = 35
	sPointTwoX = 105
	sPointTwoY = 35
	' Now we have to convert "mm" to "cm", because Inventor is measuring in "cm"
	sPointOneX = sPointOneX * 0.1
	sPointOneY = sPointOneY * 0.1
	sPointTwoX = sPointTwoX * 0.1
	sPointTwoY = sPointTwoY * 0.1
	Dim oDoc As Document = ThisApplication.ActiveDocument
	Dim oCD As ComponentDefinition = oDoc.ComponentDefinition
	' Use this line to pick the first sketch in part
	Dim oSketch As Sketch = oCD.Sketches.Item(1)
	' Or use this line to pick the sketch by name
	'Dim oSketch As Sketch = oCD.Sketches.Item("Sketch1")
	Dim oLine As SketchLine
    Dim line3 As Inventor.SketchLine
	Dim lines = oSketch.SketchLines
	 Dim tg = ThisApplication.TransientGeometry
	Dim oNewLine As SketchLine
	Dim oSketchLine As SketchLine = oSketch.SketchLines.Item(1)
oDoc.SelectSet.Clear
oDoc.SelectSet.Select(oSketchLine)
	For Each oLine In oSketch.SketchLines
		Dim OurLine As Boolean
		If oLine.StartSketchPoint.Geometry.X = sPointOneX And oLine.StartSketchPoint.Geometry.Y = sPointOneY Then
			OurLine = CheckSecond(oLine.EndSketchPoint)
			oLine.Delete()
            line3 = lines.AddByTwoPoints(tg.CreatePoint2d(1.5, 2), tg.CreatePoint2d(10.5, 2))
		Else If oLine.StartSketchPoint.Geometry.X = sPointTwoX And oLine.StartSketchPoint.Geometry.Y = sPointTwoY Then
		If OurLine = True Then
			oNewLine = oLine
			Exit For
	Next
	If Not oNewLine Is Nothing Then
		MsgBox("We've got the line")
End Sub
Private sPointOneX As Double
Private sPointOneY As Double
Private sPointTwoX As Double
Private sPointTwoY As Double
Private Function CheckSecond(oPoint As SketchPoint) As Boolean
	If oPoint.Geometry.X = sPointOneX And oPoint.Geometry.Y = sPointOneY Then
		Return True
	Else If oPoint.Geometry.X = sPointTwoX And oPoint.Geometry.Y = sPointTwoY
		Return True
	Return False
End Function
Replies (11)
Message 2 of 12
CattabianiI
Those are two completely different questions, for the second one I would keep posting on the original thread: https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/i-want-to-select-desired-line-with-i...
So about the ComponentDefinition error: what do you mean with "after opening the part"?
try to prompt or log the document full file name: MsgBox(oDoc.FullFileName)
Message 3 of 12
hayattangercekler2
I couldn't achieve what I wanted to do with the answer given there. Now if I manage to catch the line I think I could use it elsewhere but I haven't tried it. I'm trying to implement the Inventor API according to the ilogic rules I wrote last, but I can't access the "ComponentDefinition" feature in the active document. The error starts directly from here.
Message 4 of 12
CattabianiI
Try to log or messagebox the FullFileName before getting componentDefinition.
What is the exception you get?
Message 5 of 12
hayattangercekler2
OK . I did this and got the name of the file.
Message 6 of 12
CattabianiI
And the line after this message box you try to get ComponentDefinition and you get an exception?
What exception?
Message 7 of 12
hayattangercekler2
I'm very new to API. So I tried to try 2 different ways because it worked when I translated it as "AssemblyDocument". There is such an algorithm in all the ilogic codes I found. I can't understand why this feature is not available in API.
Message 8 of 12
CattabianiI
Hi @hayattangercekler2,
that's clear now 🙂
VB.Net and  iLogic allow late binding which means in your case you can call ComponentDefinition on the type Document which does not implement that property. It works at run time (in iLogic o r vbnet addin) because your startDoc variable will be a PartDocument or AssemblyDocument which have the ComponentDefinition property.
So if you are in c# you have to write code in an explicit, faster at runtime but verbose way like this one:
if (StartDoc.DocumentType == DocumentTypeEnum.kPartDocumentObject) {
  var prtDoc = StartDoc as PartDocument;
  var prtCmpDef = prtDoc.ComponentDefinition
elseif (StartDoc.DocumentType == DocumentTypeEnum.kPartDocumentObject) {
  var asmDoc = StartDoc as AssemblyDocument;
  var asmCmpDef = asmDoc.ComponentDefinition
Message 9 of 12
hayattangercekler2
Thank you so much. It worked.
Message 10 of 12
CattabianiI
About the request in the title which could be more useful for other users, post your solution into this other thread: https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/i-want-to-select-desired-line-with-i...
Message 11 of 12
hayattangercekler2
May I ask a slightly off-topic question just to get some brief information? Is it possible to assign a sheet with the Design/Insert Frame tool while in an assembly file using this line I have captured? Or should I open another issue for this?
Message 12 of 12
CattabianiI
make another post
