SketchedSymbol with Leader
wannensn
wannensn
I've managed to add a sketched symbol with a leader to a dimension. But I've problems adding a sketched symbol with a leader to an exsiting leader note.
The function SketchedSymbols.AddWithLeader always returns an error. I assume that there is a problem with the GeometryIntent.
With dimensions I use 'CreateGeometryIntent(Dimension, tmpIntentPoint)' but replacing Dimension through LeaderNote is not working.
Regards, Stephan
ekinsb
I believe this is a limitation of Inventor and not just the API.  I'm not able to create a leader to an existing leader not interactively either.
Brian Ekins
Inventor and Fusion 360 API Expert
Mod the Machine blog
wannensn
I'm able to manually create and add a SketchedSymbol with a leader to an existing LeaderNOTE (with T not D).
Stephan
wannensn
Hello Brian,
I checked this again and you are right it is not possible to manually create a sketched symbol with a leader for a simple 'LeaderNote' - sorry 😉 -  but it is possible for a 'ChamferNote' which inherits from 'LeaderNote'.
Can this be done using the API?
Thanks, Stephan
ekinsb
I verified that you can place a sketched symbol on a chamfer note.  However, I haven't had any success doing the same thing through the API.  It should work but isn't.  I've filed a change request for this to be investigated.  If you need to refer to this in future you can mention change request 1342982.
Brian Ekins
