Message 1 of 1
Sketched Symbol with Leader to Dimension
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm using the following code to create a sketched symbol and link it with a leader to a dimension. It is working for most dimensions but not all especcially radius dimension (screenshot) which are not orientated vertical or horizontal don't work. I suspect that the 'IntentPoint' is the problem, but I don't know why.
'get reference to the drawing document Dim tmpDrawingDocument As Inventor.DrawingDocument tmpDrawingDocument = mInventorApplication.ActiveDocument Dim tmpTransientGeometry As Inventor.TransientGeometry tmpTransientGeometry = mInventorApplication.TransientGeometry Dim tmpSheet As Inventor.Sheet tmpSheet = tmpDrawingDocument.ActiveSheet 'create a new sketched symbol definition Dim tmpSketchedSymbolDefintion As Inventor.SketchedSymbolDefinition = Nothing Try tmpSketchedSymbolDefintion = tmpDrawingDocument.SketchedSymbolDefinitions.Item("TEST01") Catch ex As Exception End Try If tmpSketchedSymbolDefintion Is Nothing Then tmpSketchedSymbolDefintion = tmpDrawingDocument.SketchedSymbolDefinitions.Add("TEST01") 'open the sketch of the sketched symbol definition Dim tmpSketch As Inventor.DrawingSketch tmpSketchedSymbolDefintion.Edit(tmpSketch) 'create circle Dim tmpCircle As Inventor.SketchCircle tmpCircle = tmpSketch.SketchCircles.AddByCenterRadius(tmpTransientGeometry.CreatePoint2d(0, 0), STAMP_RADIUS) 'define connection and insertion point tmpCircle.CenterSketchPoint.ConnectionPoint = True tmpCircle.CenterSketchPoint.InsertionPoint = True 'finish edit mode and save changes tmpSketchedSymbolDefintion.ExitEdit(True) End If Dim tmpCurrentSelectSet As Inventor.SelectSet Dim tmpDimension As Inventor.DrawingDimension Dim tmpObject As Object Dim i As Integer tmpCurrentSelectSet = mInventorApplication.ActiveDocument.SelectSet If tmpCurrentSelectSet.Count > 0 Then For i = 1 To tmpCurrentSelectSet.Count Step 1 tmpObject = tmpCurrentSelectSet.Item(i) If TypeOf tmpObject Is Inventor.DrawingDimension Then tmpDimension = tmpObject Dim tmpSketchedSymbol As Inventor.SketchedSymbol 'create leaderpoints Dim tmpLeaderPoints As Inventor.ObjectCollection Dim tmpLeaderPoint As Inventor.Point2d Dim tmpX, tmpY As Double tmpX = tmpDimension.Text.RangeBox.MaxPoint.X tmpY = tmpDimension.Text.RangeBox.MinPoint.Y tmpLeaderPoints = mInventorApplication.TransientObjects.CreateObjectCollection tmpLeaderPoint = tmpTransientGeometry.CreatePoint2d(tmpX + 1, tmpY + 1) tmpLeaderPoints.Add(tmpLeaderPoint) Dim tmpGeometryIntent As Inventor.GeometryIntent Dim tmpIntentPoint As Inventor.Point2d tmpIntentPoint = tmpTransientGeometry.CreatePoint2d(tmpX, tmpY) tmpGeometryIntent = tmpSheet.CreateGeometryIntent(tmpDimension, tmpIntentPoint) tmpLeaderPoints.Add(tmpGeometryIntent) 'create the new sketched symbol Try tmpSketchedSymbol = tmpSheet.SketchedSymbols.AddWithLeader(tmpSketchedSymbolDefintion, tmpLeaderPoints, 0, 1, Nothing, True, True) tmpSketchedSymbol.LeaderVisible = False Catch ex As Exception End Try tmpSketchedSymbol.Static = True End If Next End If
Regards, Stephan
