Sketched symbol with custom property
snichols
snichols
I am trying to create a sketched symbol on the fly that has custom properties in it. I am also creating the custom properties on the fly. I need to get the actual expression for the property into the sketched symbol not just a value. I need this so that I can export the drawing as an autocad .dwg that has attributes in it. Anyone have any ideas? Thanks for your tme.
snichols
Here is the code I have, any help would be appreciated even if its only to tell me it can't be done. Inventor 2009 SP2
Public Sub PartListLine()
' Set a reference to the drawing document.
' This assumes a drawing document is active.
Dim oDrawDoc As DrawingDocument
Set oDrawDoc = ThisApplication.ActiveDocument
' Set the user defined (custom) property set
Dim CustomPropSets As PropertySets
Set CustomPropSets = oDrawDoc.PropertySets
Dim CustomPropSet As PropertySet
Set CustomPropSet = CustomPropSets.Item("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}")
Dim sName As String      Dim sValue As String
sName = "PN"      sValue = "123456"
Call CustomPropSet.Add(sValue, sName)
'Update the document
oDrawDoc.Update
' Create the new sketched symbol definition.
Dim oSketchedSymbolDef As SketchedSymbolDefinition
Set oSketchedSymbolDef = oDrawDoc.SketchedSymbolDefinitions.Add("Part List")
' Open the sketched symbol definition's sketch for edit. This is done by calling the Edit
 ' method of the SketchedSymbolDefinition to obtain a DrawingSketch. This actually creates
 ' a copy of the sketched symbol definition's and opens it for edit.
Dim oSketch As DrawingSketch
Call oSketchedSymbolDef.Edit(oSketch)
Dim oTG As TransientGeometry
Set oTG = ThisApplication.TransientGeometry
' Use the functionality of the sketch to add sketched symbol graphics.
Dim oRectangleLines As SketchEntitiesEnumerator
Set oRectangleLines = oSketch.SketchLines.AddAsTwoPointRectangle(oTG.CreatePoint2d(0, 0), _
        oTG.CreatePoint2d(7.375 * 2.54, 0.1875 * 2.54))
Dim oSketchLine1 As SketchLine
Set oSketchLine1 = oSketch.SketchLines.AddByTwoPoints(oTG.CreatePoint2d(0.375 * 2.54, 0), _
        oTG.CreatePoint2d(0.375 * 2.54, 0.1875 * 2.54))
Dim oSketchLine2 As SketchLine
Set oSketchLine2 = oSketch.SketchLines.AddByTwoPoints(oTG.CreatePoint2d(0.75 * 2.54, 0), _
        oTG.CreatePoint2d(0.75 * 2.54, 0.1875 * 2.54))
Dim oSketchLine3 As SketchLine
Set oSketchLine3 = oSketch.SketchLines.AddByTwoPoints(oTG.CreatePoint2d(1.75 * 2.54, 0), _
        oTG.CreatePoint2d(1.75 * 2.54, 0.1875 * 2.54))
Dim oSketchLine4 As SketchLine
Set oSketchLine4 = oSketch.SketchLines.AddByTwoPoints(oTG.CreatePoint2d(4.75 * 2.54, 0), _
        oTG.CreatePoint2d(4.75 * 2.54, 0.1875 * 2.54))
Dim oSketchLine5 As SketchLine
Set oSketchLine5 = oSketch.SketchLines.AddByTwoPoints(oTG.CreatePoint2d(5.625 * 2.54, 0), _
        oTG.CreatePoint2d(5.625 * 2.54, 0.1875 * 2.54))
 Dim oSketchLine6 As SketchLine
Set oSketchLine6 = oSketch.SketchLines.AddByTwoPoints(oTG.CreatePoint2d(6.5 * 2.54, 0), _
        oTG.CreatePoint2d(6.5 * 2.54, 0.1875 * 2.54))
Dim oPoint As SketchPoint
Set oPoint = oSketch.SketchPoints.Add(oTG.CreatePoint2d(7.375 * 2.54, 0.1875 * 2.54))
' Make the work point of the sketch the insertion point
oPoint.InsertionPoint = True
 ''''THIS IS WHERE i WANT IT TO INSERT THE CUSTOM DRAWING PROPERTY <PN> INTO THE TEXT BOX
''''ALL I CAN GET IS THE VALUE
 'Add custom properties to the sketch symbol.
Dim oTextBox As TextBox
Set oTextBox = oSketch.TextBoxes.AddFitted(oTG.CreatePoint2d((0.375 * 2.54) / 2, (0.1875 * 2.54) / 2), _                                                      CustomPropSets.Item("User Defined Properties").Item("PN").Expression)
oTextBox.VerticalJustification = kAlignTextMiddle
oTextBox.HorizontalJustification = kAlignTextCenter
Call oSketchedSymbolDef.ExitEdit(True)
'Set a reference to the active sheet.
Dim oDrgSheet As Sheet
Set oDrgSheet = oDrawDoc.ActiveSheet
' Set a reference to the sheet's border
Dim oBorder As Border     Set oBorder = oDrgSheet.Border
Dim oPlacementPoint As Point2d
   If Not oBorder Is Nothing Then
     ' A border exists. The placement point
     ' is the top-right corner of the border.
Set oPlacementPoint = oBorder.RangeBox.MaxPoint     Else
    ' There is no border. The placement point
    ' is the top-right corner of the sheet.
Set oPlacementPoint = ThisApplication.TransientGeometry.CreatePoint2d(oDrawDoc.Width, oDrawDoc.height)
  End If
' Add an instance of the sketched symbol definition to the sheet.
' Rotate the instance by 0 degrees and scale by 1 when adding.
' The symbol will be inserted at the upper right corner of the sheet.
 Dim oSketchedSymbol As SketchedSymbol
Set oSketchedSymbol = oDrgSheet.SketchedSymbols.Add(oSketchedSymbolDef, oPlacementPoint, (0), 1)
End Sub
snichols
The code below almost gets me what I need. If I create a sketched symbol and manually insert the custom property text
when I save it as an AutoCad.dwg it has attributes. The below does not have attributes when saved the same way. Is there anyone that can explain the difference between manually inserted property text and programatically inserted property text. If you want to test this just create a custom property named PN1.
Sub PartList()
    ' a copy of the sketched symbol definition and opens it for edit.
'''''THIS GETS THE CUSTOM PROPERTY INSERTED AS AN EXPRESSION, HOWEVER WHEN I SAVE IT AS AN '''''AUTOCAD.DWG IT HAS NO ATTRIBUTES.
   Dim sText As String
   sText = "<Property Document='drawing' PropertySet='CustomPropSet' Property='PN1' FormatID= _
                                                            '{D5CDD505-2E9C-101B-9397-08002B2CF9AE}'></Property>"
   Set oTextBox = oSketch.TextBoxes.AddFitted(oTG.CreatePoint2d((0.375 * 2.54) / 2, (0.1875 * 2.54) / 2), sText)
   Else
  End If
   Set oSketchedSymbol = oDrgSheet.SketchedSymbols.Add("Part List", oPlacementPoint, (0), 1)
End Sub
hi,
you defined the PN1 custom property only inside the sketched symblo's definition, but did not set a value to that property.
I thought you could define the custom property before the sketched symbol's definition. then use it in the symbol.
add something like this before your sysmbol definition:
 ' Get the custom property set.
        Dim customPropSet As PropertySet
        customPropSet = oDrawDoc.PropertySets.Item( _
        "Inventor User Defined Properties")
        ' Create a new text property.
        Dim textValue As String
        textValue = "Here's some text."
        Call customPropSet.Add(textValue, "PN1")
good luck.
