sketch visibility of part in assembly using vba
how to turn off the visibility of a specific sketch (ex. base_Sketch) of a certain part in assembly using vba?
i know how to access a sketch in a part , what i need to figure out is how to access a sketch in a part from assembly using vba.
anyone ????
Vladimir.Ananyev
Here is VBA snippet:
  Dim oAsmDoc As AssemblyDocument
  Set oAsmDoc = ThisApplication.ActiveDocument
  'get the reference to the desired component by its name
  Dim oOcc As ComponentOccurrence
  Set oOcc = oAsmDoc.ComponentDefinition.Occurrences.ItemByName("AAA")
  'assume this is a part (not subassembly)
  Dim oDef As PartComponentDefinition
  Set oDef = oOcc.Definition
  'get the reference to the sketch by its name
  Dim oSketch As Sketch
  Set oSketch = oDef.Sketches.Item("Sketch2")
  'make sketch invisible
  oSketch.Visible = False
 cheers,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
