Title Block Definition Create and Insert API Sample doesn't work as iLogic
Hi Folks,
I've found and solved a problem with the above API sample in the Inventor 2013 API Help and thought it worth sharing:
Sub Main() CreateTitleBlockDefinition() InsertTitleBlockOnSheet() End Sub Public Sub CreateTitleBlockDefinition() ' Set a reference to the drawing document. ' This assumes a drawing document is active. Dim oDrawDoc As DrawingDocument oDrawDoc = ThisApplication.ActiveDocument ' Create the new title block defintion. Dim oTitleBlockDef As TitleBlockDefinition oTitleBlockDef = oDrawDoc.TitleBlockDefinitions.Add("Sample Title Block") ' Open the title block definition's sketch for edit. This is done by calling the Edit ' method of the TitleBlockDefinition to obtain a DrawingSketch. This actually creates ' a copy of the title block definition's and opens it for edit. Dim oSketch As DrawingSketch Call oTitleBlockDef.Edit(oSketch) Dim oTG As TransientGeometry oTG = ThisApplication.TransientGeometry ' Use the functionality of the sketch to add title block graphics. Call oSketch.SketchLines.AddAsTwoPointRectangle(oTG.CreatePoint2d(0, 0), oTG.CreatePoint2d(9, 3)) Call oSketch.SketchLines.AddByTwoPoints(oTG.CreatePoint2d(0, 1.5), oTG.CreatePoint2d(9, 1.5)) Call oSketch.SketchLines.AddByTwoPoints(oTG.CreatePoint2d(0, 2.25), oTG.CreatePoint2d(9, 2.25)) Call oSketch.SketchLines.AddByTwoPoints(oTG.CreatePoint2d(4.5, 1.5), oTG.CreatePoint2d(4.5, 2.25)) Call oSketch.SketchLines.AddByTwoPoints(oTG.CreatePoint2d(3, 2.25), oTG.CreatePoint2d(3, 3)) Call oSketch.SketchLines.AddByTwoPoints(oTG.CreatePoint2d(6, 2.25), oTG.CreatePoint2d(6, 3)) ' Add some static text to the title block. Dim sText As String sText = "TITLE BLOCK" Dim oTextBox As Inventor.TextBox oTextBox = oSketch.TextBoxes.AddFitted(oTG.CreatePoint2d(4.5, 0.75), sText) oTextBox.VerticalJustification = VerticalTextAlignmentEnum.kAlignTextMiddle oTextBox.HorizontalJustification = HorizontalTextAlignmentEnum.kAlignTextCenter sText = "Static Text" oTextBox = oSketch.TextBoxes.AddByRectangle(oTG.CreatePoint2d(0, 1.5), oTG.CreatePoint2d(4.5, 2.25), sText) oTextBox.VerticalJustification = VerticalTextAlignmentEnum.kAlignTextMiddle oTextBox.HorizontalJustification = HorizontalTextAlignmentEnum.kAlignTextCenter MessageBox.Show("Before PE", "Title") ' Add some prompted text fields. sText = "<Prompt>Enter text 1</Prompt>" oTextBox = oSketch.TextBoxes.AddByRectangle(oTG.CreatePoint2d(4.5, 1.5), oTG.CreatePoint2d(9, 2.25), sText) oTextBox.VerticalJustification = VerticalTextAlignmentEnum.kAlignTextMiddle oTextBox.HorizontalJustification = HorizontalTextAlignmentEnum.kAlignTextCenter MessageBox.Show("After PE 1", "Title") sText = "<Prompt>Enter text 2</Prompt>" oTextBox = oSketch.TextBoxes.AddByRectangle(oTG.CreatePoint2d(0, 2.25), oTG.CreatePoint2d(3, 3), sText) oTextBox.VerticalJustification = VerticalTextAlignmentEnum.kAlignTextMiddle oTextBox.HorizontalJustification = HorizontalTextAlignmentEnum.kAlignTextCenter MessageBox.Show("After PE 2", "Title") ' Add some property text. ' Add the property value of Author from the drawing sText = "<Property Document='drawing' FormatID='{F29F85E0-4FF9-1068-AB91-08002B27B3D9}' PropertyID='4' />" oTextBox = oSketch.TextBoxes.AddByRectangle(oTG.CreatePoint2d(3, 2.25), oTG.CreatePoint2d(6, 3), sText) oTextBox.VerticalJustification = VerticalTextAlignmentEnum.kAlignTextMiddle oTextBox.HorizontalJustification = HorizontalTextAlignmentEnum.kAlignTextCenter ' Add the property value of Subject from the drawing sText = "<Property Document='drawing' FormatID='{F29F85E0-4FF9-1068-AB91-08002B27B3D9}' PropertyID='3' />" oTextBox = oSketch.TextBoxes.AddByRectangle(oTG.CreatePoint2d(6, 2.25), oTG.CreatePoint2d(9, 3), sText) oTextBox.VerticalJustification = VerticalTextAlignmentEnum.kAlignTextMiddle oTextBox.HorizontalJustification = HorizontalTextAlignmentEnum.kAlignTextCenter Call oTitleBlockDef.ExitEdit(True) End Sub Public Sub InsertTitleBlockOnSheet() ' Set a reference to the drawing document. ' This assumes a drawing document is active. Dim oDrawDoc As DrawingDocument oDrawDoc = ThisApplication.ActiveDocument ' Obtain a reference to the desired border defintion. Dim oTitleBlockDef As TitleBlockDefinition oTitleBlockDef = oDrawDoc.TitleBlockDefinitions.Item("Sample Title Block") Dim oSheet As Sheet oSheet = oDrawDoc.ActiveSheet ' Check to see if the sheet already has a title block and delete it if it does. If Not oSheet.TitleBlock Is Nothing Then oSheet.TitleBlock.Delete End If ' This title block definition contains one prompted string input. An array ' must be input that contains the strings for the prompted strings. Dim sPromptStrings(0 To 1) As String sPromptStrings(0) = "String 1" sPromptStrings(1) = "String 2" ' Add an instance of the title block definition to the sheet. Dim oTitleBlock As TitleBlock oTitleBlock = oSheet.AddTitleBlock(oTitleBlockDef, , sPromptStrings) End Sub
The code works fine as VBA- but when you copy it to iLogic as I have above, the lines in bold failed because the API sample misses off the VerticalTextAlignmentEnum and HorizontalTextAlignmentEnum required by iLogic to make this work. I also had to modify the array sPromptStrings to be Dim sPromptStrings(0 To 1) As String instead of the supplied Dim sPromptStrings(1 To 2) As String - that and removing all the "Set" entries. 🙂
I do have a question though:
What does the FormatID of the Property text do? and with my post from yesterday in mind is there a way to capture that information from an existing titleblock using iLogic?
Alex Fielder
Inventor Expert
https://github.com/alexfielder/
LinkedIn - Github Inventor Extension Server - Bonkers polygon iLogic thing
Top ten iLogic Tips - API Shortcut In Google Chrome - Assembly Extrusion Example
