sketch visibility in part bij ilogic
I have a part with four sketches in it.
I also have a multi text parameter with four letters.
If parameter "A" is active I want to make sketch1 visible.
If parameter "B" is active I want to make sketch2 visible etc.
I have downloaded several codes but not work as I want.
Can someone help me get started.
rossano_praderi
Hi Jos,
this is my example as your solution.
Dim sketches As PlanarSketches = ThisApplication.ActiveDocument.ComponentDefinition.sketches
Dim oSketch As PlanarSketch
For Each oSketch In sketches
	Select Case oSketch.Name
		Case "Sketch1"
			If TestParam = "A" Then
				oSketch.Visible = True
			Else
				oSketch.Visible = False
			End If
		Case "Sketch2"
					If TestParam = "B" Then
			Else
			End If
		Case "Sketch3"
					If TestParam = "C" Then
			Else
			End If
		Case "Sketch4"
					If TestParam = "D" Then
			Else
			End If
	End Select
Next
Bregs
Rossano Praderi
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
Hi Bregs
Thanks for the solution, this works for me.
rossano_praderi
Hi Mvg, Bregs isn't my name.
Anyway, is nice to be helpful.
