Sketch Trim, Extend & Split finction
m.den.ouden
m.den.ouden
Can someone tell me where I can find the trim, extend and split function for sketches.
WCrihfield
Hi @m.den.ouden.  I don't think there are currently methods defined within the Inventor API that are exposed to us for those three tasks yet.  There are commands for them that can be executed, which will start the manual edit mode for those tasks, as long as you are already in the edit mode of a sketch when it is executed.
Those command names are:
"SketchTrimCmd" for the Trim tool
"SketchExtendCmd" for the Extend tool
"SketchSplitCmd" for the Split tool
One way to execute them is like this:
ThisApplication.CommandManager.ControlDefinitions.Item("SketchTrimCmd").Execute
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you want and have time, I would appreciate your Vote(s) for My IDEAS 💡 or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
