Message 1 of 11
04:08 AM
- Mute
- Permalink
- Report
I am trying to SWEEP a profile and a path. It fails as both are bit apart (not intersecting). So I wish to bring path upto profile. I am trying that by offsetting curves of path, upto point projected from profile.
Here is the code:
' project first point on to path's sketch plane, and then offset the path to that point so that SWEEP's profile and path will intersect Dim oStartPointProfile As SketchPoint = oProfiles.Item(1).Item(1).Item(1).StartSketchPoint Dim wpt As WorkPoint = oCompDef.WorkPoints.AddFixed(oStartPointProfile.Geometry3d, True) ' Get path's sketch Dim pathSketch As PlanarSketch = path.Item(1).SketchEntity.Parent ' Make a new sketch by copying evrything from path sketch Dim newPathSketch As PlanarSketch = CreateNewSketch(pathSketch, True) ' Get a point to offset the path to Dim newProjectedPoint As SketchPoint = newPathSketch.AddByProjectingEntity(wpt) Dim oCollection As ObjectCollection = _invApp.TransientObjects.CreateObjectCollection oCollection.Add(newPathSketch.SketchLines.Item(1)) ' Is SketchEntities better than SketchLines, hmm. crashes!! Dim offsettedentities As SketchEntitiesEnumerator = newPathSketch.OffsetSketchEntitiesUsingPoint(oCollection, newProjectedPoint.Geometry, True, False) Dim newPath As Inventor.Path = oCompDef.Features.CreatePath(offsettedentities.Item(1))
Offsetting does not work. It appears that one line has got offsetted but others did not follow. I do not want two copies, but just one offsetted closed loop path.
