- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I created a sketch line with following vba codes. When I measure the length on Inventor, the length is 10x longer than the actual length. (measured 14.142, it should be 1.4142). Anything wrong?
Sub Test()
Dim app As Application
Dim doc As Document
Set app = ThisApplication
Set doc = app.ActiveDocument
Dim partDef As PartComponentDefinition
Set partDef = doc.ComponentDefinition
Dim sk As PlanarSketch
Set sk = partDef.Sketches.Add(partDef.WorkPlanes(3))
sk.Edit
Dim tg As TransientGeometry
Set tg = app.TransientGeometry
Dim myStart As Point2d
Set myStart = tg.CreatePoint2d(0, 0)
Dim myEnd As Point2d
Set myEnd = tg.CreatePoint2d(1, 1)
Call sk.SketchLines.AddByTwoPoints(myStart, myEnd)
sk.ExitEdit
End Sub
