Sketch dimension between circle to circle using vba
k14348
k14348
     I would like to add one dimension between circle to circle offset distance.
Could you help me on this.
Option Explicit
Sub CreateSketch()
    Dim oApp As Inventor.Application
    Set oApp = ThisApplication
    Dim oFmgr As String
    oFmgr = oApp.FileManager.GetTemplateFile(kPartDocumentObject, kMetricSystemOfMeasure)
    Dim oPartDoc As PartDocument
    Set oPartDoc = oApp.Documents.Add(kPartDocumentObject, oFmgr, True)
    Dim oTG As TransientGeometry
    Set oTG = oApp.TransientGeometry
    Dim oSketch As PlanarSketch
    Set oSketch = oPartDoc.ComponentDefinition.Sketches.Add(oPartDoc.ComponentDefinition.WorkPlanes.Item(3))
    Dim oOrgPoint As SketchPoint
    Set oOrgPoint = oSketch.AddByProjectingEntity(oPartDoc.ComponentDefinition.WorkPoints(1))
    'Call oSketch.SketchLines.AddAsTwoPointCenteredRectangle(oTG.CreatePoint2d(0, 0), oTG.CreatePoint2d(50, 50))
    'Call oSketch.SketchCircles.AddByCenterRadius(oTG.CreatePoint2d(0, 0), 50)
    Dim oSkCir As SketchCircles
    Set oSkCir = oSketch.SketchCircles
    Dim oCir As SketchCircle
    Set oCir = oSkCir.AddByCenterRadius(oTG.CreatePoint2d(0, 0), 50)
    Call oSketch.GeometricConstraints.AddCoincident(oOrgPoint, oCir.CenterSketchPoint)
    Call oSketch.DimensionConstraints.AddDiameter(oCir, oTG.CreatePoint2d(60, 60), False)
    Dim oOffsetCol As ObjectCollection
    Set oOffsetCol = oApp.TransientObjects.CreateObjectCollection
    oOffsetCol.Add oCir
    Call oSketch.OffsetSketchEntitiesUsingDistance(oOffsetCol, 10, False, False, True)
    Call oSketch.DimensionConstraints.AddOffset(oCir, oOffsetCol, oTG.CreatePoint2d(70, 70), False)
    oApp.ActiveView.Fit
    Dim oProfile As Profile
    Set oProfile = oSketch.Profiles.AddForSolid
    Dim oExt As ExtrudeDefinition
    Set oExt = oPartDoc.ComponentDefinition.Features.ExtrudeFeatures.CreateExtrudeDefinition(oProfile, kNewBodyOperation)
    Call oExt.SetDistanceExtent(10, kSymmetricExtentDirection)
    Dim oExtFeat As ExtrudeFeature
    Set oExtFeat = oPartDoc.ComponentDefinition.Features.ExtrudeFeatures.Add(oExt)
End Sub
Karth
JelteDeJong
try using a tangent distance constraint between the 2 circles. like this:
Option Explicit
Sub CreateSketch()
    Dim oFmgr As String
    oOffsetCol.Add oCir
    Dim oCir2 As SketchEntitiesEnumerator
    Set oCir2 = oSketch.OffsetSketchEntitiesUsingDistance(oOffsetCol, 10, False, False, True)
    Call oSketch.DimensionConstraints.AddTangentDistance(oCir, oCir2.Item(1), oTG.CreatePoint2d(10, 50), oTG.CreatePoint2d(40, 40), oTG.CreatePoint2d(70, 70), False)
    oApp.ActiveView.Fit
End Sub
Jelte de Jong
Blog: hjalte.nl - github.com
k14348
    When we do manually we dont pick tangent edges. can't we select both circle and take dimension?
_Karth
